Sick dude she's coming along nicely this is one sweet build
Looks great. What spindles are you going to use? I hope you don't use the 94-95 with the mach K member. The rack location is way wrong for those spindles. You'll get a ton of bumpsteer
Love the swap.... can't wait to see it finished.
nice progress!
Has little to do with a bumpsteer kit. It has to do with the height of the rack. The height of the rack is an inch lower then on the 96-04 K members. That's why you see the tie rod arm dip down. So essentially if you put a bumpsteer kit on it, you will make it worse.
I will check but it didn't look that bad. I will take a pic and post it.
Version 1. HCI
Version 2. On3 Turbo Kit
Version 3. Mach 1 4v swap
Current Version Eaton Swap Mach 1 4v
September Ride of the Month 2014
March Ride of the Month 2016
So this is what I have. With a bumpsteer kit it should bring the arm down even with the rack.
Version 1. HCI
Man j have some spindles you can have cheap.
03 COBRA
http://www.sn95forums.com/showthread.php?68817-The-03
95 GT vert(rip)
98 COBRA
http://www.sn95forums.com/showthread.php?53612-98-cobra
It's getting there man... Looks good
Contrary to popular belief, the tie rod does not have to be parallel to the ground, only parallel to the control arm. However a bumpsteer kit won't fix the differences in 95 spindles on a 96+ K member and rack. That is a structural height difference. Unless you move the pivot point of the control arms up as well, there is no way to get around it. Just an FYI. Go to maximum motorsports and read all about it if you'd like. I had no idea until I read theirs and a few others articles.
Good luck hope the spindles help....
03 COBRA
95 GT vert(rip)
98 COBRA
Version 1. HCI
Finished the wiring and connected the battery everything looks to be good, dash and all lights came on so far so good.
Also got some new parts.
New stifflers trans crossmember that will work with the longer 3650.
Version 1. HCI
Received my new valve covers.
Before.
After!
Everything looks very clean and good.
Version 1. HCI
gorgeous!
1999 Ford Mustang V6:
RIP Red Car (Original Build Thread)
Number Tew Build Thread 4.3 Stroker V6
February 2013 ROTM (Woooo!)
House Build Thead
Welcome to the greatest mustang community on the web.
awesome stuff man! But don't use 95 spindles! Maximum Motorsports explains why on their website.. you can't solve that with bumpsteerkit, get the 96+ spindles.
Bookmarks
