become a supporting member
Page 7 of 7 FirstFirst ... 34567
Results 121 to 140 of 140
  1. #121
    YUNG VEEZU's Avatar
    Badges
    Join Date
    Mar 2009
    Ft. Carson, CO
    Posts
    260
    Feedback
    Post Thanks / Likes Stats
    Just updating, I know this thread has slowed down a lot due to weather, along with work and family. But the sun finally came out and I was able to somewhat get a tiny bit of work done. I connected the speedometer connector, with the rest of the wiring harness along the transmission. I had to halt progress again because of the power steering pump (That one 10 mm bolt that is hard to get to takes forever to turn). Other than that I just gave her a little wash.
    US ARMY OEF Veteran 11-12 / 49ERs / 97 Cobra / 89 5.0 Notchback
  2. DKblue98GT, Tillerman77 liked this post.
  3. #122
    YUNG VEEZU's Avatar
    Badges
    Join Date
    Mar 2009
    Ft. Carson, CO
    Posts
    260
    Feedback
    It took me an hour to finish up reinstalling the power steering pump. That one bolt that you have to put in first is a real pain but after a couple of beers it wasn't too bad. I reinstalled the AC compressor, but had to jack the engine up a few inches to clear one of the bolts.
    rerouted the cables to the battery, fuse box and other grounds:
    reinstalled the power steering reservoir and both coil packs:
    reinstalled the header / exhaust hoses under the passenger side oil pack:
    it was a tight fit, I had to slightly bend it towards the motor, and had to be careful with the AC lines
  4. Tillerman77 liked this post.
  5. #123
    MorbidSvtCobra's Avatar
    Badges
    Join Date
    Oct 2016
    Posts
    10
    Feedback
    Making progress brother! Almost there! My cobra is borderline done,they are rewiring new tps lines cause my old plug connector was brittle and broke into pieces,my engine is primed and ready to fire up then tune and its done. Heres a pic i took friday when i was at the shop. Dam this engine looked old and beat b4
    Pro flow 80mm mass air meter with filter
    NGK tr6 plugs
    Screaming Demon coil packs
    Ford racing 9mm Wires
    Bassani Offroad-X Pipe
    Aluminum Driveshaft
    Steeda under drive pulleys
    Steeda tri-Ax Short shifter
    Ford racing cobra leather shift knob
    Tokico Illuminas 5-way adjustable shock/struts
    Aluminum radiator
    Weld in Subframe connectors,
    thrush mufflers
    fuel pressure regulator
    Upr firewall adjuster and quadrant
    Ford racing leather shift knob
    Phantom fuel pressure and water temp gauges with dual pod
  6. YUNG VEEZU, Tillerman77 liked this post.
    YUNG VEEZU said thanks for this post.
  7. #124
    Nighttrain's Avatar
    Badges
    500+ Forum Reputation
    Join Date
    Jun 2016
    Atglen pennsylvania
    Posts
    1,429
    Feedback
    Quote Originally Posted by YUNG VEEZU View Post
    Hey bud! Know its been a while life's been crazy busy but hows progress? Got it running yet?
    95 boss gt
    Mac cai
    3"Magnaflow cat back
    Gutted h pipe
    Hurst short throw
    Gt40 H/C/I
    3.73 9" rear
    "RIP"
  8. #125
    YUNG VEEZU's Avatar
    Badges
    Join Date
    Mar 2009
    Ft. Carson, CO
    Posts
    260
    Feedback
    Quote Originally Posted by Nighttrain View Post
    Yes!! Actually today I had a buddy help me reinstall the driveshaft, midpipe, transmission mount, speedometer cable etc., around the lower part of the vehicle. I couldn't take any pictures because my son is due to be born either this week or next week! More pictures to come!
  9. #126
    Tillerman77's Avatar
    Badges
    Join Date
    Sep 2016
    Southern MN
    Posts
    40
    Feedback
    Good to hear. Your new baby (almost here) will become your main priority now. Hope everything goes great.
  10. YUNG VEEZU liked this post.
  11. #127
    Nighttrain's Avatar
    Badges
    Join Date
    Jun 2016
    Atglen pennsylvania
    Posts
    1,429
    Feedback
    Any progress is good progress. Congrats on the baby. They change your life fast!
    95 boss gt
    Mac cai
    Gutted h pipe
    Hurst short throw
    Gt40 H/C/I
    3.73 9" rear
    "RIP"
  12. YUNG VEEZU liked this post.
  13. #128
    96blak54's Avatar
    Badges
    500+ Forum Reputation 5000+ Forum Posts
    Join Date
    Feb 2011
    Ky
    Posts
    5,836
    Feedback
    1   (100%)
    ^ true, for the better!
    Be sure to ask the mommy if its ok you spend time elsewhere or be prepared to here about it!.
    Sent from my SM-G900P using Tapatalk
  14. YUNG VEEZU liked this post.
  15. #129
    YUNG VEEZU's Avatar
    Badges
    Join Date
    Mar 2009
    Ft. Carson, CO
    Posts
    260
    Feedback
    I am back!!! Sorry no pictures yet, I wanted to update you guys ASAP. My buddy and I were able to put almost everything together.
    I had to jack the motor up again in order to get the last AC compressor bolt in, and connect one of the negative cables from the motor to the body. We reconnected all electrical connectors, and vacuum lines. Then we put the IMRC on, then the intake manifold on, all with new gaskets. 2 of the stupid upper intake manifold bolts broke . My fault, I tightened them way too tight. We put the throttle body on, cold air intake, installed the belt, radiator and hoses and spark plugs. Filled her up with oil, coolant, and transmission fluid.
    BUT now she won't start. She will crank, thats about it. We took a few hours trouble shooting:
    -we checked all spark plugs, everything is good
    -starter is hooked up correctly
    -battery is good
    -there is fuel pressure
    -we cleaned the MAF
    -my friend says he thinks the timing is off, but I left everything the way it was before I tore it down
    (just a note, the stock alarm is still on the car, plus my aftermarket alarm. Not sure if that would affect anything)
    Besides that, a flat tire and a few webs, she should be running soon!
    any ideas?
  16. Tillerman77 liked this post.
  17. #130
    evilcw311's Avatar
    Badges
    Join Date
    May 2010
    Louisville, KY
    Posts
    4,115
    Feedback
    Not starting as in?!?? Does starter turn the motor over and it doesn't fire or it won't even turn?? Does it sputter at all or is it just rotating quietly?!?
    Video of what it's doing may help
    95 Satin black on wicked black leather, black chrome fr500's, blacked out boosted 351 being dropped in as you read this......
  18. #131
    lwarrior1016's Avatar
    Badges
    SN95 Supporting Member 5+ Successful iTrader Deals 500+ Forum Reputation
    Join Date
    Sep 2014
    Posts
    4,824
    Feedback
    5   (100%)
    Did you put the crank sensor trigger wheel back in?
    “MR SECONDARY TIMING CHAIN”
    Rio Red 98 GT
    Always Under Construction
  19. #132
    96blak54's Avatar
    Badges
    Join Date
    Feb 2011
    Ky
    Posts
    5,836
    Feedback
    1   (100%)
    Oh dang ^
  20. #133
    YUNG VEEZU's Avatar
    Badges
    Join Date
    Mar 2009
    Ft. Carson, CO
    Posts
    260
    Feedback
    Quote Originally Posted by lwarrior1016 View Post
    yes, my friend installed that piece.
    pictures:
    webs
    flat tire over the year
    here the video:
    https://youtu.be/Sxf_ElaW8Ik
  21. #134
    96blak54's Avatar
    Badges
    Join Date
    Feb 2011
    Ky
    Posts
    5,836
    Feedback
    1   (100%)
    Oh, boy.....hope u got the cams timed right......on the correct banks and correct valve.
  22. YUNG VEEZU liked this post.
  23. #135
    96blak54's Avatar
    Badges
    Join Date
    Feb 2011
    Ky
    Posts
    5,836
    Feedback
    1   (100%)
    Pull the oil stick and smell the oil. If its got one hind of gas smell, stop trying to start it.
  24. YUNG VEEZU liked this post.
  25. #136
    evilcw311's Avatar
    Badges
    Join Date
    May 2010
    Louisville, KY
    Posts
    4,115
    Feedback
    Obviously your battery is low but that doesn't sound right. I'm not a mod guy but if definitely sounds like it's fighting itself as it turns over which leads me to agree with 96blak54 about timing issues.
  26. YUNG VEEZU liked this post.
  27. #137
    YUNG VEEZU's Avatar
    Badges
    Join Date
    Mar 2009
    Ft. Carson, CO
    Posts
    260
    Feedback
    Quote Originally Posted by 96blak54 View Post
    yea thats what my friend said. When I took them to the machine shop the guys said they didn't move the cams at all. When I reinstalled the cam chain and guide they were all in the exact same spot as before. We may have to take the valve covers off and take a look
  28. #138
    YUNG VEEZU's Avatar
    Badges
    Join Date
    Mar 2009
    Ft. Carson, CO
    Posts
    260
    Feedback
    Just wanted to check in...no further progress. She's still sitting in my driveway sadly, I'm hoping to get her started by Christmas
  29. #139
    96blak54's Avatar
    Badges
    Join Date
    Feb 2011
    Ky
    Posts
    5,836
    Feedback
    1   (100%)
    Dang...man where u live at? Ill come by and slap it together real quick
  30. YUNG VEEZU liked this post.
  31. #140
    Badges
    Join Date
    Mar 2007
    Posts
    475
    Feedback
    You mentioned something very important which is the aftermarket alarm. If you left out the wire that disables start or it has a break or wire is corroded car will never start. Besides that makes sure injectors are connected in right order as well as spark plug wires. You may want to get a battery maintainer as it’s crankin slow due to to many failed attempts.
  32. YUNG VEEZU liked this post.
Similar Threads
  1. Twin Turbo Cobra Just blew a head gasket.
    By TT94SVT in forum The Garage
    Last Post: 11-24-2014, 12:53 AM
  2. Well, I think the head gasket is blown
    By superslow86 in forum 96-04 - 2V Specific
    Last Post: 09-05-2013, 10:44 PM
  3. Blown head gasket??
    By Fets in forum 96-04 - 2V Specific
    Last Post: 07-21-2008, 08:05 PM
  4. Intake gasket blown
    By Rice_slayer in forum 94-95 5.0 - Specific
    Last Post: 06-20-2008, 12:06 PM
  5. Possible blown head gasket?
    By Murder after Midnight in forum 96-04 - 2V Specific
    Last Post: 02-18-2008, 06:07 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
