become a supporting member
Page 6 of 17 FirstFirst ... 234567891016 ... LastLast
Results 101 to 120 of 321
  1. #101
    OLD H2S's Avatar
    Badges
    SN95 Supporting Member
    Join Date
    Jul 2015
    Silver Spring Maryland
    Posts
    663
    Feedback
    Post Thanks / Likes Stats
    I think the gasket is not happy with the Edelbrock intake because of the amount cut off of the heads and block.
    Got My Eye On You
    I'm not picking my nose
    I'm porting my upper intake manifold
  2. #102
    OLD H2S's Avatar
    Badges
    Join Date
    Jul 2015
    Posts
    663
    Feedback
    The Eddy mounting flanges are smaller than the stock PI intake on the inner lip toward the center of the motor.
    Got My Eye On You
  3. #103
    96blak54's Avatar
    Badges
    500+ Forum Reputation 5000+ Forum Posts
    Join Date
    Feb 2011
    Ky
    Posts
    5,928
    Feedback
    1   (100%)
    Not leaving enough room for error?
  4. #104
    OLD H2S's Avatar
    Badges
    Join Date
    Jul 2015
    Posts
    663
    Feedback
    I am going back to the PI manifold, it fits much better. The extra 6 HP is not worth the PITA.
    Got My Eye On You
  5. #105
    OLD H2S's Avatar
    Badges
    Join Date
    Jul 2015
    Posts
    663
    Feedback
    Got it started for 1 minuet then water on the floor????? the heater core let go.. Replaced the heater core and the car runs much better with the PI manifold, fish tails now even with new sticky tires. Car will not warm up with the big radiator and 180 degree thermostat in 32 degree weather. Beat the crap out of it for 3 hours and the low coolant light came on so it is still leaking, just slower. Tomorrow I will do a compression check and post numbers. the fan switch for the heat/ac inside the car is not working and has no power going to the connector,
    I do not know where the missed connection is? I am getting a drive line vibration above 80 mph?
    Got My Eye On You
  6. #106
    Burninriverdiver's Avatar
    Badges
    Join Date
    Jan 2014
    Akron OH
    Posts
    2,296
    Feedback
    I'm glad you got to rip on it a bit, sounds like the bugs are going to need chasing but you're making progress!
  7. #107
    96blak54's Avatar
    Badges
    Join Date
    Feb 2011
    Ky
    Posts
    5,928
    Feedback
    1   (100%)
    Definitely running the problrm down. Ill agree a night and day difference with the pi intake.
    Good to see progress! Youll be carving corners reliable soon at this pace. Keep the updates coming
  8. #108
    OLD H2S's Avatar
    Badges
    Join Date
    Jul 2015
    Posts
    663
    Feedback
    I FINALLY FOUND IT. Number 8 intake port, pin hole found it with a 20 power ridgid endoscope. Now how do I fit it? Spot is on the corner radius of the short side floor, too acute of an angle to us the laser, too deep to use a straight TIG electrode. I have a small right angle TIG head but it takes electrodes that are too small to heat up the massive heat sink that a car head is. With all the machine work I have a big investment in the heads, with 180cc ports and big intake valves with 43mm seats these are over kill for my little street motor but Boy do they rev...instantly!
    I do have a set of NPI heads that I molested some, but would need alot of work to get back to 14:1 compression.
    Got My Eye On You
  9. #109
    evilcw311's Avatar
    Badges
    Join Date
    May 2010
    Louisville, KY
    Posts
    4,231
    Feedback
    Just put some chewing gum in there!!!! ;-)
    95 Satin black on wicked black leather, black chrome fr500's, blacked out boosted 351 being dropped in as you read this......
  10. #110
    OLD H2S's Avatar
    Badges
    Join Date
    Jul 2015
    Posts
    663
    Feedback
    If I could get it from the back side of the crack..
    Got My Eye On You
  11. #111
    OLD H2S's Avatar
    Badges
    Join Date
    Jul 2015
    Posts
    663
    Feedback
    How about I make a right angle electrode. Take a 3/32 tungsten electrode and cut 1/2" off and use the laser to weld them back with the tip at a 90 degree angle?
    Got My Eye On You
  12. #112
    OLD H2S's Avatar
    Badges
    Join Date
    Jul 2015
    Posts
    663
    Feedback
    I have not found any right angle TIG electrodes on the web. It will take me 5 min. to crank one out
    Got My Eye On You
  13. #113
    lwarrior1016's Avatar
    Badges
    SN95 Supporting Member 5+ Successful iTrader Deals 500+ Forum Reputation
    Join Date
    Sep 2014
    Posts
    4,866
    Feedback
    5   (100%)
    A right angle TIG electrode? That sounds very interesting and it sounds like it might just work. There has to be a way to get it, someone out there has the secret to doing port welding.
    If you make that electrode, could you take some pictures for me? Could you show us where the hole is too?
    “MR SECONDARY TIMING CHAIN”
    Rio Red 98 GT
    Always Under Construction
  14. #114
    OLD H2S's Avatar
    Badges
    Join Date
    Jul 2015
    Posts
    663
    Feedback
    I'll make up the electrode today, and work on the gas cup for it. Might take longer to get the motor out and brake it down to show the hole. Some days the car and engine acts like it is put together with Velcro and some days with super glue..
    Got My Eye On You
  15. #115
    Badges
    Join Date
    Sep 2014
    Posts
    4,866
    Feedback
    5   (100%)
    Quote Originally Posted by OLD H2S View Post
    Are you going to weld it back up without taking the engine down?
    Rio Red 98 GT
  16. #116
    OLD H2S's Avatar
    Badges
    Join Date
    Jul 2015
    Posts
    663
    Feedback
    No, The heads must come off to do the repair, and pull the valves out to reach the hole, might be easier from the valve side. The head studs will not let the heads off with out pulling the motor, so...
    The TIG electrode did not work, well, it worked a little. The joint is much too brittle like cast iron repair, and the tungsten has a much higher melting point than anything else which is why we use it. Cranked the laser up to 400 volts and blew the rod in half so I had enough power to do the job but I see the right way it is going to be a heated jig that holds the angle and run it up to 3000 degrees then start the laser and at the same time rotate the jig all inside an Argon bath. Damn, and I left my resistance welding machine to do the preheat in China 10 years ago. Probably have to make the jig out of Carbon..
    It did work and I will post pics tonight but it was too delicate and would not stand up to normal welding rigors so I played with it for a half hour and stopped.
    Got My Eye On You
  17. #117
    96blak54's Avatar
    Badges
    Join Date
    Feb 2011
    Ky
    Posts
    5,928
    Feedback
    1   (100%)
    So it be easier to do different heads?
  18. #118
    OLD H2S's Avatar
    Badges
    Join Date
    Jul 2015
    Posts
    663
    Feedback
    NPI Doctor, help.
    Got My Eye On You
  19. #119
    OLD H2S's Avatar
    Badges
    Join Date
    Jul 2015
    Posts
    663
    Feedback
    Problem is I have 1000.00 in the PI heads, did the guides, stainless valves, Comp Cams springs and retainers, ported to 180cc intake ports, 43mm seat ports, 25cc chambers..but they are over kill on a 300hp engine. I should repair them and send them to Will or you.
    Got My Eye On You
  20. #120
    OLD H2S's Avatar
    Badges
    Join Date
    Jul 2015
    Posts
    663
    Feedback
    Here is a shot of the TIG electrode, very cool but a pain to make which is why there are none on the internet for sale.
    Got My Eye On You
Similar Threads
  1. Replies: 7
    Last Post: 09-22-2013, 02:43 PM
  2. 95 5l auto "spark knock" "pinging" problem
    By Dirtcar75 in forum 94-95 5.0 - Specific
    Last Post: 05-04-2012, 11:39 PM
  3. Replies: 121
    Last Post: 02-21-2012, 07:45 PM
  4. Replies: 4
    Last Post: 08-16-2011, 09:19 AM
  5. Replies: 11
    Last Post: 05-20-2010, 11:39 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
