become a supporting member
Page 3 of 6 FirstFirst 123456 LastLast
Results 41 to 60 of 106
  1. #41
    Badges
    Year 2006 OG
    Join Date
    Jan 2006
    Posts
    195
    Feedback
    1   (100%)
    Post Thanks / Likes Stats
    Went ahead and rehosted everything to IMGUR. Major PITA, but hopefully it'll be smooth sailing from here on out.
    So I bought a set of BMR tubular SFC's. These were a new offering from BMR. I've used their parts on other cars (mostly my CTS-V) with great luck so I thought I would give it a shot. I figured since I would just do the occasional HPDE or something, full length wouldn't be entirely necessary. Plus, BMR offered me a generous discount to essentially test them out since they didn't have a 96-98 Cobra (or any 94-98 for that matter) for prototyping. It turns out, the front frame mount interferes with the cross member mount. I conferred with BMR and they will be developing a new set specifically for SN95's. BMR generously offered to sent a prepaid return label, but I decided that I'm going to cut and modify them to attach at the same point the trans cross member mount. I have not yet done the install, but here are the initial pictures.
    In other news, she's getting old.
    1997 Pacific Green Cobra
  2. #42
    lwarrior1016's Avatar
    Badges
    SN95 Supporting Member 5+ Successful iTrader Deals 500+ Forum Reputation
    Join Date
    Sep 2014
    Posts
    4,858
    Feedback
    5   (100%)
    Those would work on a 94-98 Gt. The transmission mount is further forward than the cobra.
    What you mean, "getting old"? That thing is a baby! lol
    “MR SECONDARY TIMING CHAIN”
    Rio Red 98 GT
    Always Under Construction
  3. #43
    Badges
    Year 2006 OG
    Join Date
    Jan 2006
    Posts
    195
    Feedback
    1   (100%)
    Couple little pieces added.
    FRPP 03/04 style shift knob, since my OEM knob was a bit worn. I must admit, I really like the grip and weight of this new knob.
    I got a Diode Dynamics LED interior light kit. Not as bright as I wanted, but the color is good.
    And lastly, these showed up. Ceramic coated FRPP shorties. Got a great deal, now I just have to deal with the headache of installing them. I have future clutch/transmission plans so long tubes weren't going to be on my list.
  4. #44
    Badges
    Join Date
    Dec 2009
    Posts
    880
    Feedback
    1   (100%)
    I'm curious to see those subframe connectors installed. I have the same shift knob and it's really comfortable. I'm also curious to see if notice much of a difference from the headers.
    1997 Cobra
  5. #45
    Badges
    Year 2006 OG
    Join Date
    Jan 2006
    Posts
    195
    Feedback
    1   (100%)
    Car is up on jack stands now. She'll be getting the FRPP shorties installed and I also got a set of used Bilstein quad shocks to round out the package. I'll update with pictures later.
  6. #46
    Badges
    Year 2006 OG
    Join Date
    Jan 2006
    Posts
    195
    Feedback
    1   (100%)
    Got the Bilstein quads installed. They had so much more pressure than the factory quads. Not sure if I'll feel a difference or not, but at least I know I have good ones on there now.
    I also started on the headers. Wow, I was not expecting so much difficulty. I started with the drivers side. So far I have the mid pipe out, battery out, steering shaft disconnected, motor mount unbolted and engine jacked up, rear EGR disconnected, and 5 of the 8 fasteners out. I do believe I'll have to remove the oil filter to get to the AIR connection at the front as well as the front three lower bolts, which are the only ones that remain.
    I'm half tempted to just go ahead and order new poly motor mounts since I'll have them pretty much out anyway.
  7. #47
    RedTwilight's Avatar
    Badges
    Join Date
    Jun 2011
    Roxboro, NC
    Posts
    515
    Feedback
    Why not get a good set of tubular rear upper and lower control arms then ditch the quad shocks all together?
    Header swaps are a huge pain on the 4V cars. Even more so with the factory K member.
    Trinity
    "The God of Death is back from Hell"
    "I will obliterate all the stars...
    in their place I will hang a black paper moon!"
    RedTwilight ZERO 1996 Laser Red SVT Cobra
    1993 Silver LX Coupe
  8. #48
    Badges
    Join Date
    Dec 2009
    Posts
    880
    Feedback
    1   (100%)
    Man, I wouldn't even attempt to install headers without dropping the K member. Now would be a great time for poly motor mounts. My old motor mounts had no rubber left between the metal plates...
    1997 Cobra
  9. #49
    Badges
    Year 2006 OG
    Join Date
    Jan 2006
    Posts
    195
    Feedback
    1   (100%)
    Quote Originally Posted by RedTwilight View Post
    I have a set of lowers, not interested in uppers as I'm more concerned with handling than straight line performance. Maximum Motorsports recommends keeping quads if you can.
    Quote Originally Posted by DKblue98GT View Post
    I really don't want to have to drop the K. I just know I would never feel comfortable reassembling it and not having to spend the money on another alignment (just had one done when I did the suspension). Actually, I think once I have the motor mount removed from the engine, doing the headers won't be as bad. I went ahead and ordered some prothane mounts from LMR.
  10. #50
    Badges
    Year 2006 OG
    Join Date
    Jan 2006
    Posts
    195
    Feedback
    1   (100%)
    Update on the headers. Should have just dropped the K.
    Driver's side mount and manifold are out. In the process of jacking up the drivers side, I punctured one of the heater hoses on the passenger side. FML.
  11. #51
    Badges
    Year 2006 OG
    Join Date
    Jan 2006
    Posts
    195
    Feedback
    1   (100%)
    Did a little bit more today.
    Here's a shot of the hose that got punctured. Not what I was wanting to happen, but whatever.
    And these things are a major PITA.
    These SAI fittings fought me every inch of the way. And so did removing the plugs for the SAI fittings. Impact FTW. Went back together with a helping of anti seize.
    And the driver's side is in.
    Now, I have to wait until Monday until my prothane motor mounts come in. Also, my battery hold down bolt was broke so I had to drill it out and I'll have to replace it.
    Plan of attack for this weekend: Install battery (unhooked), probably drop the starter. Then after the motor mounts come in, I can reinstall the drivers side, reinstall oil filter, hook up steering shaft, then start on the passenger side.
    Also, the headers weigh 4lbs less per side, so a total of 8lbs lost.
  12. #52
    Badges
    Join Date
    Dec 2009
    Posts
    880
    Feedback
    1   (100%)
    Holy crap, I can barely believe you got the header on. Nice work!
    1997 Cobra
  13. #53
    Badges
    Year 2006 OG
    Join Date
    Jan 2006
    Posts
    195
    Feedback
    1   (100%)
    You and me both. Starter is out. Battery is reinstalled. 6 of 8 of the bolts are out of the passenger side. SAI disconnected at the valve. Literally can't do any more until I get the motor mounts in and button up the drivers side so I can lift the passenger side and remove the motor mount.
  14. #54
    Badges
    Join Date
    Aug 2015
    SoCal
    Posts
    Feedback
    Great thread. Makes me want to start working the 97 Cobra sitting my garage.
  15. #55
    Badges
    Year 2006 OG
    Join Date
    Jan 2006
    Posts
    195
    Feedback
    1   (100%)
    Update. Both headers are in, both motor mounts are in. Tonight I'll finish up installing the K-Member brace, starter, mid pipe, strut tower brace, air intake, and replace the punctured heater hose. Then I should be able to fire it up and heat cycle it once while it's still in the air then go through and re-torque the bolts that I can reach without taking anything apart.
    Also, I don't know if I mentioned this before, but I welded the hardware to the header flanges so I won't have to throw a wrench on the top of them. That'll make it a heck of a lot easier to install the mid pipe.
    For anyone that's doing this, the hardest part of the job bar none is the SAI connections. Also, don't remove the dipstick if you don't absolutely have to.
    Sorry I didn't take many pictures, I'm doing this project solo in piecemeal as I have time.
    Passenger side from underneath
    Drivers side from underneath with steering shaft hooked up.
    Passenger side SAI connection
    Pretty new motor mount
    Passenger side from above
  16. Tillerman77 liked this post.
  17. #56
    Badges
    Join Date
    Sep 2014
    Posts
    4,858
    Feedback
    5   (100%)
    Great work man, I applaud you for doing this without dropping the k member.
    Rio Red 98 GT
  18. #57
    Badges
    Year 2006 OG
    Join Date
    Jan 2006
    Posts
    195
    Feedback
    1   (100%)
    All done. Started up and warmed up. I'm going to go back over the fasteners again today (the ones I can reach) and make sure everything is snugged up. I'll do this again after about another couple weeks.
    I did notice immediately that the poly motor mounts give some significant vibration between about 1200-1600 RPM. I took a video but Imgur won't let me upload videos.
  19. #58
    Badges
    Join Date
    Dec 2009
    Posts
    880
    Feedback
    1   (100%)
    Nice work! I have the same motor mounts and don't have any vibration. check you your harmonic balancer just to make sure it's not separating. Do you notice a difference in performance with the headers?
    1997 Cobra
  20. #59
    Badges
    Year 2006 OG
    Join Date
    Jan 2006
    Posts
    195
    Feedback
    1   (100%)
    It's still on jack stands. I haven't driven it yet. Wanted to get one heat cycle through it and retorque the fasteners. I've heard similar stories about the poly mounts but also heard that they settle a bit over time. I'll update once I drive it.
  21. #60
    Badges
    Year 2006 OG
    Join Date
    Jan 2006
    Posts
    195
    Feedback
    1   (100%)
    Put a few miles on the car since the headers/motor mounts. Seems to run a bit better. Not extremely noticeable, but it certainly feels like it has more mid range punch. The extra vibrations are bothering me though. I went ahead and placed an order for the March P1158-08 fluid harmonic damper plus ARP fastener. Hopefully it'll smooth out the engine some which should reduce the amount of vibration I feel through the steering wheel. That's where it's most noticeable.
    On a less pleasant note, as I was at Street Car Takeover last weekend, my recently replaced drivers side window regulator failed. I was going to order OEM Ford ($$) but it would've taken several days for it to arrive and I didn't want the car to be down with the door apart for so long. Instead, I went to NAPA and got their lifetime warranty regulator. I didn't take any pictures because I was in pissed off mode and it's a dirty nasty job. What sucks even worse is my door panel insert (switch panel) broke as well during the job. So I ordered an OEM Ford door panel insert from LMR along with some of their saddle tan interior paint since they don't make saddle tan versions anywhere.
    This car has got me like:
Similar Threads
  1. Want To Buy: Pacific Green Cobra Spoiler or trunk w/o holes
    By pittshady in forum Wanted (WTB / WTT)
    Last Post: 02-07-2017, 11:18 PM
  2. FS!! Unmolested 44k Pacific Green Cobra !!!
    By Shifty Powers in forum Cars, Trucks, Motorcycles, and Vehicles
    Last Post: 09-25-2012, 09:08 AM
  3. 1997 mustang cobra PAC green $8000
    By ALS97GT in forum Cars, Trucks, Motorcycles, and Vehicles
    Last Post: 06-14-2012, 05:14 PM
  4. My Pacific Green 96 GT with 58k
    By 96gtseastang in forum Members Rides
    Last Post: 06-05-2008, 10:25 PM
  5. My Pacific Green 98
    By 1fine69 in forum Members Rides
    Last Post: 09-22-2007, 08:45 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
