Highlighted posts from Friday, Apr. 22, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
April 21, 2022 * 21 posts * 86 views
lwarrior1016 said: TB and MAF should be fine, you'd be surprised how much extra air can be used when you're spraying a bunch of nitrous. Do you make sure the window switch is working correctly? Also, ... Read more >>
April 21, 2022 * 20 posts * 118 views
joemomma said: Yeah I'm running them off a 5-channel along with the rears and sub. Someone (Crutchfield maybe?) has the Morel Tempo Ultra on sale for $250. I should probably jump on that. I have ... Read more >>
April 21, 2022 * 11 posts * 111 views
Makoto said: sounds like you learned the lesson, losing it never helps anything. one time i was going for a little drive and i noticed my fuel gauge was going towards empty WAY too fast. barely ... Read more >>
April 21, 2022 * 8 posts * 43 views
Blackhippy2016 said: I just bought some new driveshaft bolts since I had lost my old ones however when I try and install them it gets really difficult. Is just because of the loctitie that is on them ... Read more >>
April 21, 2022 * 11 posts * 26 views
chithead said: I jokingly refer to our Mustang as, "Blueptie" - combination (or abomination) of the words blue and hooptie. Anywho, thought I'd start a separate thread here for the audio adventures ... Read more >>
April 22, 2022 * 24 posts * 305 views
OpalFrostGT said: Looks very thorough! How many screw and bolt holes did you cover? That's something that I would probably realize I had done when it was too late! Thanks for sharing your photos! Read more >>
April 21, 2022 * 8 posts * 112 views
NicksGTR said: When installing my manual trans tunnel piece I ground both mating surfaces clean and used SEM 2 part epoxy and glued it in place. Worked like a charm and you couldn't chisel that ... Read more >>
April 21, 2022 * 21 posts * 239 views
d.garza18 said: Gotcha! Yeah I pulled valve body off yesterday and it has metal in it... looks like I'll have an evening of work today Read more >>
April 22, 2022 * 38 posts * 488 views
J_lope82 said: That Trickflow plenum looks like it's a good product. I might just pair it up with the BBK TB that the car came with. Anyone used the Trickflow before? Read more >>
April 22, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Mach 460 Tweeter pods April 20, 2022 * 10 posts * 59 views Exterior and Interior Note to self: Don't drive angry! April 20, 2022 ... Read more >>
Continue reading...
RevJon
