Is that a Tri-Ax shifter? I'm digging the angle of that handle. My Hurst leaves a little to be desired - I'm thinking about picking up a new handle for it.
yep. with the pool ball knob it feels just right.
if you know someone that can weld you can make a small cut in your handle just enough to allow you to bend it into place and then weld it back together solid.Is that a Tri-Ax shifter? I'm digging the angle of that handle. My Hurst leaves a little to be desired - I'm thinking about picking up a new handle for it.
somebody is addicted. Just curious, I have been surprised to that 3d printers seem to struggle with making a perfect circle as I can normally see the multiple straight lines that make up the curve. Is it just a resolution thing that it takes longer to make a perfect arc or is just hard to melt the filament in a perfect arc?
You could slow it down for final pieces if that would improve "quality".
