‘97 Cobra Restomod
Makoto
Makoto
Houston
AC and heater are done. She's been running great.
Next weekend the tuner is supposed to reset the idle.
I'm gonna try and put break in miles on this thing while I wait for the new year since I can't get it inspected (and thusly registered) without cats in this county.
Break in miles on what? Go out and beat on it. Total seal recommends that you go straight to racing on new rings to make sure they break in properly.
Makoto
Makoto
Houston
rings are good, she was dyno'd and made good power, no smoke. sounds awesome. now its just normal 500-1000 mile break take it easy for a bit to help the bearings last.
ford calls for it on all their new cars, too. its pretty standard. plus, i've got all new brakes, diff, and gears all assembled by the lowest bidder (me) so I wanna be cautious for a bit.
To each his own I guess. My engines get assembled and go straight to making wide open blasts, given the tune is good of course. Same with my transmissions and differentials. A couple runs through the gears and make sure it shifts, then let it rip.
If you survived the dyno time, there’s nothing you’ll do on the street that’ll blow it up.
Makoto
Makoto
Houston
Oh i know, I think this is more about bearing life long term. It would probably be fine either way, I'd like to put a few hundred easy going miles on it first just to get a feel for things and work out bugs anyhow.
Makoto
Makoto
Houston
window switches and door locks officially relocated with vintage style switches. now i can start mocking up the console.
I will tip my hat to you for integrating into the window wiring because of all the wiring that could have been in there it is the hardest to diagnose/troubleshoot/ect.
Makoto
Makoto
Houston
thanks man, it did take some head scratchin. now that I have everything I need working in the car I can start deleting wiring.
Makoto
Makoto
Houston
I've made some decisions.
No center console.
the 01+ oem unit looks a lot cleaner than the earlier versions and has flat surfaces i can mount the switches to. trying to locate one now.
doors: Scott rod door panels.int.jpg
Makoto
Makoto
Houston
switches, 03+ anniversary console and shifter bezel.
It all needs refinishing but you can see where I'm going now.
I'm still working out the exact shape i want for the cover plate.
Makoto
Makoto
Houston
The dash flat black was more of a semi gloss so it doesn't quite match the true flat for the console. It'll do for now.
Makoto
Makoto
Houston
Had to destroy a ecoboost lincoln that thought it could outpace a cobra. First time I ever gave it the full beans. Felt so flippin good, y'all.
The tuner tamed the idle a smidge and I decided she needs some resonators.
Also, got the materials to do the sidepipes
Makoto
Makoto
Houston
took me a bit to get the proportions where i wanted them. I want to make a sort of heat shield cover to mask the fact that one side is 3cm longer than the other.dp1.jpgdp2.jpgdp3.jpg
Makoto
Makoto
Houston
Nope, generic unbranded seats. They're good but if you have broad shoulders like me you'll need to mod them a smidge. I got em when they were like half the listed price.
