‘97 Cobra Restomod
Makoto
Makoto
Houston
I gave flux core wire a try because this is stainless and it is now abundantly clear that this year i've got to get a tig. I gotta make some covers anyways but here's them waiting on the hangers and new mufflers. These did help with the noise a bit. I'm hoping the magnaflow resonators I've got coming will do the last bit of taming to the sound I need.
Makoto
Makoto
Houston
Here you can see the pipes going to the side exhaust. i'm going to add 2 magnaflow round mufflers where those long straight sections are, as well, to tame the sound a bit more.
Makoto
Makoto
Houston
here's the upclose of one side and yeah i did through the floor subframe connectors (that's those beefy 2" box frames welded in the interior with the outriggers going to the sills).
Makoto
Makoto
Houston
Thanks guys, here's the full shot of the whole shabang before i stick the magnaflow mufflers in.
Makoto
Makoto
Houston
the magnaflows really toned down the harshness of the exhaust note. its not quiet now but it did seem to take the edge off in a big way. i think my truck is now louder than this thing :D Also, i didn't lose any ground clearance so that's cool. win win. In other not so awesome news I think my diff has to much backlash causing a thunk when i go from reverse to forward gears or if i'm not super smooth when i shift. so that's annoying.
The clunk is very common on irs cars and is most likely from slack in the cv axles. I put brand new Ford axles in mine and after a little while it started clunking again.
Makoto
Makoto
Houston
I think i solved the thunk. the rear diff mount bolts were a little loose. haven't taken it for a drive yet but the thunk is gone on jackstands. if it happens again i'll throw some loctite on them bolts. stupid rain keeping me from playing right now.
Makoto
Makoto
Houston
working on designing the covers for the exhaust and rockers. i'm pretty sold on using some angle aluminum to achieve the clean look but im thinking i may need to make something more robust to handle the wind at high speeds.
Makoto
Makoto
Houston
Makoto
Makoto
Houston
not yet. I'm trying to come up with a better way to secure to to the door and eliminate creaking but i'll keep that in mind.
oh but ya know what i do need? something nice to plug that hole left by the manual crank i won't be using.
marktuck99
