“Back in Black”…
RAU03MACH
NEW MEXICO
I dont think there are any
When your putting a wide tire on the rear
The wider the more tire on the pavement
Harder to channel out the water on the road
RAU03MACH
NEW MEXICO
I had Goodyear aqua treads on my truck
That were 15x10.5 rear
And that shit was no good in the rain
Daryl
Daryl
SoCal
So what about scaling the offset down? Say, stock 255/45x17 fronts and a 275/40 or 285/45 rear?
RAU03MACH
NEW MEXICO
Anything thats wide is not good in rain or snow
Put some truck tires on it mud slingers
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
I run 285/40 18 Goodyear eagle gt super car tires on the back of mine and they do pretty well in the rain.
weendoggy
Wow! I use my Nitto 555G2's in wet track weather and yes, they'll slide, but it's controlled by my right foot. Also run a square setup.
RAU03MACH
NEW MEXICO
Tell me that when it hardly ever rains and the sun is backing the oil out of the ground and when it dose rain slicker than snot
92wastheyear
Up here in Oregon, the first rain of Fall is brutal for that reason. After that though, it is manageable. That said, I still drove my truck (2002 F150 Screw) all winter
RAU03MACH
NEW MEXICO
We only get rain for 2 months total rest sun is blistering the road
And a lot of cars hear will catch fire from oil leaks because of the heat
Oil on the road looks like a mirror reflection off the road
And when it rains good God the oil water mix is crazy
Pump the brakes you'll slide and rear end someone
If your not expecting it going to fast
Daryl
Daryl
SoCal
Lwarrior, I’m running 17’s but I’ll check out , see if they have in my diameter.
The Goodyears we don’t tend to consider because they’re a brand that frequently comes on new cars did we can’t wait to get rid of them. But, truth be told, though their tread wear may fall short of other brands due to their softer compounds, they DO ride nice and handle well in wet.
lwarrior1016
South Mississippi
I will say that, the tread does not last as long as I thought it would. They were put on August of 2020, and they are close to needing replaced. I’m thinking august of this year will call for another set, but they are a 220 treadwear and I don’t drive it easy. It’s my daily and sees A LOT of burnouts. I will be using them again.
TN95gt
