Hi! I'm new here. I've followed WarHorseRacing on Youtube and lurked some on here since I bought my Mustang and would like his and/or other's advise on building a balanced suspension for my street ride.
The Situation
I bought my 2002 Mustang V6 5 spd with 245K miles on it a while back with the goal in mind to just have a nice resto-mod project and final product. I'm older now and don't care about being the fastest (longitudinally or laterally), best looking or sounding.
Even if I did care, I'm on an extreme budget with this and can't afford to anyway. I also don't have the luxury of a concrete driveway, so I will be working with jack stands sitting on plywood, what sits on dirt/grass.
I want a nice Mustang that is reasonably sporty. I may not even ever upgrade the wheels. Part of the selling point of this car for me was it has the good looking factory mags on it that I don't desperately want to change.
I have another vehicle I'm using as primary transportation right now, but would absolutely love to get this Mustang to primary driver status!
The car looks to have a rebuilt front end suspension, so that means new rubber bushings and ball joints I don't have to worry about, and the steering is just fine.
The springs have a typical sag of these 24 yr old cars and probably the equivalent of I'd say, 1" lowering springs. I cant be accurate on that. The camber of the front wheels is noticeable, with the lower portion of the front wheels sticking out more than the upper. It's actually sitting exactly where I'd like for it to sit for a nice sporty look if I were to keep these wheels (not too low).
The absolute number one issue that has to be addressed first is the rear end being too loose. Turning a corner feels like the car is going to slide right off of the rear axle or something. It's a bit unsettling. I'm probably making it sound worse than it is, and I'm sure you guys know what I'm talking about. I don't think it actually slides that much but it isn't a solid brick, either. That coupled with the weakened springs and bump steer from being "naturally lowered", has all got to be rectified.
So on top of addressing these issues, I want to tighten up the cornering ability a bit over stock without compromising the NVH too much. I enjoy the ride as it is now and probably would much more if it were new. I know I'll have to compromise some, though. Just not too much. I should probably also mention that I've owned and driven other Mustangs, one of them being a stock 90 GT, and I pretty much hated that ride. Due to my experiences with that one, I am also VERY aware of the snap oversteer issue, what causes it, and would like to reduce chances of that as much as possible.
Here is the parts list as planned so far.
Got:
Rebuilt front end minus springs
GT rear sway bar (24 mm)
Rear shock tower brace
Front strut tower brace
Going to get:
GT front sway bar with poly bushings (to match the rear)
New or used GT springs all around, cut to lower back down to desired reasonable height
New rubber spring isolators
New struts and shocks for GTs that are about 10% stiffer to match the cut GT springs
Caster/Camber alignment kit
Bump steer kit
Aftermarket lower control arms with multi-piece, greasable poly bushings
That basically sums it up.
What do you guys think? Is that a good balance? Wouldn't that tighten things up and get rid of some of the looseness of the rear end?
Now, the reason I didn't include the upper rear control arms is something I wanted to consult you guys about. I understand these will be important in rectifying the rear sway, but how important? I've seen guys say the LCA replacements really tighten up their rear ends to the point they didn't need anything else.
I also don't want a huge increase in NVH and changing these arms and their bushings would also mean going way up under the car where I might not be so comfortable under the current situation or paying someone extra to do it.
I need your guy's input on the NVH levels and if this is necessary. I'm willing to compromise some, just not A LOT.
If I were to do it I understand switching to poly on the frame end but staying with stock rubber on the rear end housing mounts is the way to go. Should I put in new rubber on that end? Would the old bushings being so old make it more pliable so it can articulate more or would they make it more unpredictable? I mean, it is a good thing or a bad thing?
Let me know what you guys think.
The Situation
Got:
Going to get:
Bump steer kit
