02 Torch Stang
TORCH
TORCH
Athens,Alabama
I ordered a torsion bar with splined ends. I went off of Nasa's rules in case i want to race with them. Then had to modify one side to accommodate the splines being off.
But was able to preload it if i need to instead of adjusting the tie rod ends. It worked out really nice.
On the front i took a 30mm stock sway bar and cut the ends and fabbed up 1/2 flat plate with a 30° angle to clear the tires at full turn. But it shortened the arm so the bar might be stiffer.
Oh very cool, never thought about that. You never know what your getting online so I was hoping it wasn't just a piece of pipe ya twisted up :)
TORCH
TORCH
Athens,Alabama
ttocs and 96blak54, The hood on the car was just setting on it and i'll get the other pics for the wing.
I did add the hood pins.
TORCH
TORCH
Athens,Alabama
I started on the front with the K Member and suspension which helped with the new radiator mount. Sway bar and rotor cooling were easy to get figured out.
ah ok. I thought the hose was under the frame rail where the bar mounts. Have you put a wheel on it yet to make sure that its not going to rub that hose? I thought the wheels got pretty close to the side at full crank. You can always put steering rack limiters in if its an issue but I am sure you know that.
TORCH
TORCH
Athens,Alabama
Yea, I need to check it. Haven't done that again. I have driven the car doing some tuning . This is 2 years worth of pictures. I got more pictures.
TORCH
TORCH
Athens,Alabama
Any body been on Barbers or Road Atlanta in a Stang. if so what speed did you get up to on the back strait away.
virocanah
