03 gen2 twin turbo coyote swap
kennyz
Been doing some big changes to the car again. Think I've owned this car since 07 best I did with the built 2v was 9.5s @ 140s
Decided to do a junk yard coyote swap at the end of last summer.. what a ride its been, and its not done yet.
Gen2 out of a f150 60k miles
Mustang cams and phasers
Pac 1234 springs
Oil pump gears and sprocket
ARP head studs
With a holley HP ecu
Here are some of the progress pictures
Engine brake down time.
This is were it got interesting when I first picked up the engine I did a leak down test and everything checked out great, well I should have opened it up a took a look under the covers. Oooof she was dirty. Change your oil people.
So I sent the heads off to modularheadshop.com they did am amazing job cleaning them up.20210909_175214.jpg20210909_175141.jpg
kennyz
kennyz
20220609_233925.jpg20211007_102344.jpg20211008_100431.jpg20211008_112036.jpg20211114_050952.jpg20211118_053431.jpg
Hopefully I did all that correctly
I went with the CG twin turbo hotside. Im not fond of the wastegate location and have decided to change the locations later on in the build
kennyz
kennyz
Second thing I noticed with the turbo kit was if I was going to keep power brakes and steering I was going to have to figure out what to do with the alternator. The power by the hour is a great kit but there is no room for the turbos and the alternator.. made up a bracket for the AC location 20211213_102956.jpg20211207_131326.jpg20220109_141143.jpg20211213_120508.jpg
kennyz
kennyz
Out with the ol 2v.. this thing was an awesome engine and is still running strong I plan using later on another build maybe.. if someone doesn't buy it off me..
20200531_162035.jpg20220127_102137.jpg20220209_140454.jpg20220215_155006.jpg20220220_155159.jpg
50HSN95
Minnesota
That's a pretty amazing looking motor swap! Are those Scott Rod panels in the engine bay ahead of the shock towers?
When you timed that engine, did you follow the Ford procedure for setting the chains? Gen 1 and gen 2 are different
joe65
yeah damn, 9.5 is slow nowadays. :p. I like the car and the swap. I had one to swap and chickened out (gen2 mustang coyote). Tell me about the 2v specs? any head work done? forged short block...i'm guessing. lol
kennyz
kennyz
2v stroker engine 8:9:1
Manley pistons notced
Manley rods
Forged crank
Arp hardware
Stage 3 heads ported PI heads
Modular head shop turbo cams
kennyz
kennyz
The two top outputs are the ones im talking about. I read that there not needed was wondering what you did with them
Those two outputs don’t need to be assigned. The Holley guys told me that stuff is handled in the background, so you don’t lose I/O potential.
jarthur1995
