Hi all new to the forums needing some help plz.
ok 03 GT mostly stock (exhaust and intake)
car was running great parked it, the next morning crank no start.. a shot of starting fluid started right up run for a few sec and died.
ok fuel problem, checked the switch in the trunk not triped. unpluged wire and checked voltage to the fuel pump control module and have 11.59v and ground.
plug module back in and voltage droped to 2v on the + side, I think ok a short on the fuel pump or wire going to the pump.
drop the tank have 11.59v to the pump IF I unplug the ground.. plug groung back in and + side drops to 2v..
I think ok pump has a internal ground problem, replace the pump same thing have tryed 4 pumps from 4 places..
every now and then it will start (1/30 tryes if that) will stay running for anywhere from 10 sec to 2-3 min then dies and back to no start..
I got a fuel pump control module just to try it and no change..
I really have no clue where to go from here.
