10 inch wheels up front
the5.ohh
Shaolin, NY
Someone tag Brett, I forgot his username on here. IIRC he's running 10-10.5''s up front
sleepn_sn95
Indy
I ran 9.75's up front and I had a small amount of clearance but that was with 255's. You will need a wheel with the right offset and bs. Most 18x10 "mustang" wheels will require a spacer. I remember seeing a black sn95 cobra with black 18x10 fr500's all around. IIRC it is the 98 drift cobra
chris91
Cincinnati, OH
Thankfully the New Edge has more room up front. I will be running a 285/30/18 up front soon.
sleepn_sn95
Indy
3/8" spacers and 275/35/18's from what I read. I believe it is [MENTION=20381]Vortecd4v[/MENTION] car
I don't know how great that will be on the street. I had issues with 275's jumping in and out of the ruts the big trucks made in the highway and dropped back down to a 255 on a 9" front. I would assume you will be running at least a 275 on a 10" front if you go that route.
lutter94
South Dakota
I have 275's up front, but it rubs the sway bar on hard right turns. Left is fine....must be really close....
DKblue98GT
I have 275/40/17 on 17 x 9 and they rub a bit. They almost stick out too far beyond the fender to look good.
Shifty Powers is running a 295 in the front. With a tad bit of camber you could easily get away with 305s still in the fender. The tricky part is getting the right backspacing on the wheel so that you don't require spacers and the wheel doesn't rub on the inside.
CC'S95GT
Hampton ,Ga.
I ran a 17x9 with 275-40 tires on the front for a week with no issues other than a slight rub at full lock.
D3VST8R96GT
D3VST8R96GT
Marble Fall, AZ
I'm not too worried about stick out...
I might need to invest in more spacers.
As far as offset 3/8s is an additional -9.5mm on a "normal" mustang wheel ......I need to wheel shop I'm just gonna do it and deal with the outcome lol
marktuck99
