11's in the 1/4
98gtmadness
hello all! this is my first post n ima newbee from philly, my question is can u get a 98gt to run 11's in the 1/4 mile?
my mod list is:
pi heads w/ pi cams
accufab t/b and plen
mac long tubes
mac h-pipe
flowmaster 40's cat back
u/d pullies
k&n fipk
4.10's gears
now if i get the heads ported wit vt stage 2 cams, 24 lb injectors n fuel pump could i get into 11's??
also what kind of suspension work should i do?
i was also thinkin of puttin on moser 31 axels and 31 spline differential?
as u can see im tryin to break 11's with no power adders, help!!
11's with no power adder in a 98 GT ??? ??? ??? :rollinglaugh: :rollinglaugh: :rollinglaugh:
Sorry man thats not going to happen I dont think. You would have to get your car down to like 3000 pounds or less to even be close to getting a time like that, plus you would need a lot of power to run that fast. It could be done I guess but it would take a lot of work in the right places :-\ getting that weight down would be first on my list, the mass of that car is killing you. You have a nice sounding set up for a motor, but im not sure if its enough to put you in the 11's :dunno:
smokinya9
with your mods know what kind of times are you running now. 11s going to be hard try stroking it DROP A LOT OF WEIGHT.do you have auto or standard you will need some sticky tires for sure give us alitte more info on you car any suspension work etc. so we can see how much time you need to drop to get to your goal in the 11s and you will also need a great tune
ALITL8
here's a pretty cool link... Online Dyno. you can throw some variables (numbers) in and get a general idea of whats possible under perfect conditions. at 3000 lbs with 350hp you "could" achieve a high 11. the weight of my car with a 1/4-1/2 tank, subwoofer in (10" in enclosure), i dont remember if my spare was in, full upholstery and my ass is 3520 lbs... getting to 3000 lbs might be a little tricky.
my tuner is going to be building a NPI motor with the PI intake swap, hand ported PI heads, stage III cams, forged bottom end, etc., etc. for me and it should make 300-350rwhp. i think thats about all you can pull out of these motors without a power adder :dunno:
do you have a baseline dyno or track time for your car yet?
jpajkos
bore your motor out .30 over. A very aggressive cams, heads, intake, full bolt ons, gears,full exhaust, a really good tune, and a 100 shot you have your 11s
he wanted to stay N/A
Scott 96Cobra(rip)
Exactly ....... Not to mention a proper rim size and an excellent Slick.
Your gonna want a forged motor for that kind of power.
On the suspension, start with LCA's and Subs
Maximummotorsports.com
There's a number of other suspension options, depensd on what you want to do and how much $$ you want to install.
ck5.0
Subframes and Control Arms would be a good start.
Stangman98
First off...it is possible to do.
You are not going to get there with 4.10's though you are going to need at least 4.30's
Next you are going to need a nice set of cams with valve springs. You can plan on spinning that motor to at least
6500. They are right though. You are going to really have to take weight out of the car. You will need to be close if not under 3000 lbs. with you in it. Next off if going to be tire selection. I would recommend a 26*10 ET Drag on 15x10 wheel. You are going to need suspension work...Subframes, control arms, I would recommend at least a 6pt bar. Tubular front end would help also.
You would be better served to mount the battery in the trunk also. If you are runnning a stock diff and axles don't even think about going 11's. I have destroyed more rearend parts then I care to admit. Suggestion...Detroit Locker and Strange 31 Spline Axles, that will solve any rearend issues you may have! Alot of it will come down to get the launch right and praticing after you get the power you need. Also, once you have the power GET A TUNE!! You will not get in the 11's without one.
My '98 about 3 weeks ago in 40* weather at about 3350 lbs
This is running a 12.78 @ 105 so I still have a way to go...
It can be done NA as said above but the easiest way to do it is with some nitrous or a supercharger. Pick yourself up a forged shortblock and 150 shot of nitrous or a blower with 10-15lbs of boost and you'll get your 11's as long as you take care of the suspension to get traction.
I think you guys have gotten away from what he was asking, he listed his mods and asked what else he would need to get 11's and I assume he was planning on keeping his existing motor.....I think :dunno: This is why I said it would be VERY VERY hard to do with that stock block.
Obviously if you get a built motor with all the fancy power making stuff to go with it 11's can be done without a lot of trouble, but to do it and utilize the factory bottom end is another story.
Stangman98
It can be done with a stock shortblock. You just have to concern your self with the intake side of the motor, fuel, cams, tune, ect, and you can get yourself there.
oh yea, how about those stock pistons :D
*Whoa Snap*
Well I'd suggest you add up the different alternitaves.
Top end engine work, and major suspension along with weight savings - vs - stronger motor and NOS or a blower??
Just curious - why do you want to stan NA?
Let us know what you think, Madness.
ALITL8
maybe he's scared to go "really" fast :dunno:
how fast you reckon you'd go if you did the strong motor, built rear, wieght reduction to 3K, suspension and sprayed, blown or turboed :naughty:
jpajkos
I think its just to say he ran 11s N/A. I know I would be stoked running 11s with just all motor. 8)
bs.austin.tx
