Preorders are open-
https://www.fullytorquedracing.com/mustang/sn95-13-rear-brake-bracket.html Use coupon code EARLYBIRD for a discount
*Please* read the FAQs and "important notes" but if you really don't want to, I'm here to answer questions.
Preorders placed before November 2nd will be guaranteed to ship the week of November 14th. Orders placed after this cutoff will be shipped on a first-come, first-served basis.
IMPORTANT NOTES
• This kit has no parking brake provision. There are many hydraulic options on the market if you need to retain parking brake functionality.
• Installation of a proportioning valve is recommended, as the addition of much larger rear brakes throws off the stock brake bias. We recommend the Wilwood 260-12627 proportioning valve. Installation is fairly straightforward and does not take very long. You must also disable the stock proportioning block by removing the internals and replacing the plug.
• The 8.8 axles are considered "floating c-clip axles", meaning that they have ~0.04" of lateral play in them. The 2 piston cobra calipers are semi-floating, meaning that they rely on the lateral movement of the pads and pins to keep from experiencing piston knockback. Therefore, it is extremely important that the edges of the pads (where the pads meet the caliper bracket) are properly lubricated with brake grease. Failure to keep this surface properly lubricated can result in knock back and/or excessive dragging. In our testing, there are no knockback or binding issues with a properly maintained braking system.
• If the pad seats are not properly maintained, sound will be evident under hard cornering. Please keep in mind that these calipers may make more noise than the stock calipers when subjected to cornering forces.
• Due to Ford's less-than-perfect production tolerances, it is possible that some cars have spacing that is out-of-spec for what our brake kit supports. Therefore, shims are included with the kit to correct the rotor-to-caliper lateral spacing. This distance can vary quite a bit, if you have any questions please send us and email and we will help you measure to see if you will require additional shims.
• This kit uses a rotor that was originally designed for the front, so the rotor bore is slightly larger than the rear hub bore. The kit includes 0.01" thick shim strips which are used to center the rotor properly.
Sent from my iPad using Tapatalk Pro
