1994 Bonnet (sorry, Hood!) not sitting right
tmwsccsh
England
Hi all,
The car has been away from me for a couple of weeks as there was an issue with the brake lines - sprayed the inspector doing the annual safety check as they split at the test!
All sorted now and I've got her back, but I've notice that the bonnet is not sitting right - it's up on the right-hand-side (as you look at it from the front - see below). The right-side of the image shows more of the top of the headlight than the left.
I thought it looked a bit odd as I was driving back and that the catch hadn't taken but it's firmly shut.
I noticed there's a couple of rubber stops on the front of the inside bonnet which I thought could be adjusted to angle the fit, but I'm not seeing how to shift them.
Clearly I need to raise the left-hand side (as you look at the picture) - is there an easy adjuster I've missed somewhere???
Thanks in advance.
TMW
07GtS197
Fort Myers, Fl
Those rubber stops are how it’s adjusted. You turn them clockwise to lower and counterclockwise to raise them as they’re threaded. Don’t adjust them too high or else the hood latch won’t catch completely or you’ll have to slam the hood to catch.
tmwsccsh
tmwsccsh
England
Cheers.
I shall persevere with them a bit more. I had a feeling they were the case but didn't want to force anything in case I wasn't right.
TMW
Snorky
My cowl 95R hood has a similar issue. Top of the hood aligns perfectly with thr fenders drivers side underneath comes down fiether and pressed on the head light which opened my headlight. Just make sure it's not pressing on your head light
Cregar24
