1994 mustang gt a/c issues
applehead
Hello,
My a/c blows hot after a couple of years of very cold. No noticeable leaks that I can see. Adding refrigerant to top off at 45 degrees PSI not fixing the problem. Compressor clutch engages every 15-20 seconds as if low on refrigerant. Manifold gaskets show low side at aformentioned 45 degrees PSI but the high side at 50 degrees PSI!
Is this a bad compressor even if it engages intermittently? Will a vacuum and refill solve the problem? Is another part of the system causing a low high pressure reading?
Maybe the clutch portion of the compressor will fix the problem?
Too many questions, would like to narrow down.
Thanks
cobrajeff96
Germany
It's likely either a leak, either one of the pressure switches malfunctioning, or the compressor no longer compresses, or any combination of the three. Those rattle cans are pretty unreliable and a good way to throw money away. Take it to a shop with an actual A/C cart like a Robin Air or something similar. It's worth the small fee.
Slice
Toronto Canada
In my experience fixing air conditioning that won't hold a refill and function is never cheap and the fixes frequently don't last either.
applehead
applehead
I pulled the connector and paper clipped the two electrical contacts and the compressor engaged. I checked the continuity of the switch and got the tone. According to my gauges there is freon in the system at 40- 50 PSI. High pressure gauge reads 50 PSI. Should I bypass at ac relay to get the compressor engaging kind of like a jumpstart to allow freon to enter and flow? Despite continuity should I still replace pressure switch? I am thinking as soon as freon flows then high pressure gauge will rise to closer to 200 PSI?
Either way I dont think the compressor is bad. What do you think?
Thank.
07GtS197
Fort Myers, Fl
What’s it showing on the low side? If it’s the same as the high side while the compressor in engaged, the compressor isn’t working.
applehead
applehead
45 PSI low side, 50 PSI high side engine off. Will check when compressor engaged in a couple hours.
applehead
applehead
So I pulled out manifold gauges. I noticed as soon as I added refrigerant to about 45 psi the clutch engaged. But only off, then on. So as soon as I hit 65 psi did the clutch fully engage and with it cold ac. My assumption was 40-50 psi was the max to fill. 65-70 psi is the magic number. With engine on ( 1st image ) gauges read 25 psi, 185 psi. Cabin temp is 37 degrees.
Engine off ( 2nd image ). I will check in a week to see if things are stabilized. As for now, everything is good and no expensive parts to buy and replace.
Thanks.
Mustang5L5
What's your ambient (outside) temp, as ideal pressures vary based on conditions.
25psi low side/185psi high side would be ideal for ambient temps of 50-55 degrees.
If you are 80-85 degrees, you want a charge that gives you about 40-45psi low side and 200 psi on the high side. 100 degrees would be about 50-55psi low side and 250ish high side. You really want to charge based off weight and adjust, but not everyone has the right equipment to do this so rule-of-thumb with pressures might be the best some can accomplish.
Keep an eye on things but you might need to add more at some point. Regardless, if you topped off, you have a leak you need to track down.
Miltoid
Is the compressor noisy? It should be making more pressure on the high side. How cold, to the touch, is the low-pressure line at the evaporator. If it's cold you might have a temp door problem.
applehead
applehead
Right now in southern California it is 75-80 degrees. The cabin vents are blowing 35-37 degrees. I'm sure there is a small leak but I can't see it with the naked eye. I know the high pressure is below normal but for now I am going to leave it as it is and monitor. Will let you know if anything pops up.
Thank you.
badass98svt
Fixed my AC last summer. It was a bad O-ring where you fill it.
Cost was under $10
I definitely got lucky though.
nynce
