1994 Mustang GT Weird Miss
xdkylexd
Southern IN
Ok I bought my 1994 GT stock a month ago. It now has 410 gears ac smog egr delete transgo shift kit msd cap rotor coil. I also replaced the plugs fuel and air filter.. Now I have a strange miss between 4-5k it almost completely stops. Also have a surging idle and when I put it in gear it almost wants to die. When its warmed up.
Im going to change to 9mm plug wires.
I checked fuel pressure idling it was at 36psi I dont know where these cars are supposed to be but I have to drop the tank to fix my float anyway.
Any one had an issue like this?
Thanks in advance!
the fuel pressure is supposed about 40psi with the vacuum disconnected.
Whe mine was missing in the upper RPM's, it was the stock coil breaking down.
Surging idle is usually because of a vacuum leak.
X
xdkylexd
Southern IN
I hope its not the coil its only two weeks old
Sent from my DROID RAZR using Tapatalk
X
xdkylexd
Southern IN
Well I've been driving it all week.. maybe the plug wires are breaking down
When ever mine runs rough or I get a missfire First thing I go is the basic tune up, Plugs, wires cap and rotor and fuel filter.
Have you ck'd for codes? You can have one set without the CEL being on.
X
xdkylexd
Southern IN
Fixed the idle issue found a slew of old cracked vacuum lines replaced them and it idles fine but still has a miss I'm gonna say its plugs that's the only thing I haven't replaced
Phatboy
Mine had a high RPM miss and even though it passed all the testing it turned out to be a bad TPS.
