1995 intermidiate steering shaft replacement
clayton
My 95 gt has a lot of slop in the steering, the plastic part inside got damaged due to header heat. I found a 1996 shaft from a salvage yard that seems to be in great shape. According to some guys, it will work in my 95. According to some research on Google, it says the 96 shaft wont work due to the rag joint differences at the bottom. Does anyone have the answer to this, before I get it replaced?
Ctucker
Pennsylvania
Just did mine after 27yrs. Go with a maximum motorsports shaft. You won't be disappointed at all. Tightened it right up. Pricey but we'll worth the money. LMR has them in stock as where going to Maximum Motorsport doesn't. They were waiting on u joints to come in.
clayton
clayton
Good to know. Thanks. Reason i asked if the factory shaft from a 96 will work in my 95, is because I already have the one out of a 1996.
96blak54
Staff member
Lawrenceburg Kentucky
Wow! I didnt know something like this was a potential problem. Thanks for posting it!
Can you get a few pics of what you are talking about?
clayton
clayton
Unfortunately no, the car is at the shop with the current shaft still intact, and I just dropped off the replacement shaft today. So we will see if it works.
RossA81
Monkton, MD
It will work. I put an 03 Cobra shaft in my 95 Cobra.. this was once a pretty popular replacement as they are supposedly a little beefier who knows if thats true tho.
Ross
clayton
clayton
Thanks man!!! I was hoping for that answer. Ofcourse the internet says no, because the rag joint is different.
sway
Staff online
