1995 mustang gt no fuel no spark
Mustangt1995
I bought the car not running the guy I bought it from said it had no spark so when I brought it home I found the timing chain was broke I replaced it but when I tried to crank it I have no spark or fuel I was reading somewhere to check the injectors red wire was hot and it wasn't but when I accidentally put the ground on test light to positive and touched the red wire i herd the fuel pump come on I have no knowledge on mustangs any help would be appreciated
Michael Plummer
Brockton, MA
Always remember the following: Air, Fuel, Spark and Compression when it comes time to diagnose a problem with your Mustang. Seeing that you're new to Mustangs and if you want to do the work yourself I suggest the following web site for testing procedures: http://easyautodiagnostics.com/ford/4.9L-5.0L-5.8L/index-of-articles-1
The members here are also a source of information. If you take your time to read and re-read you should be fine. If you can't find your answer, then posting a question is always best. I'm not sure what tools or test equipment you have but with the web site above, I'm going to recommend a Chilton's Manual for your car. http://www.amazon.com/Ford-Mustang-through-Updated-Chiltons/dp/1563926490
To check your injectors, I like using a noid light: http://easyautodiagnostics.com/misc-index/noid-light-tool-review-1
To check for spark use a spark tester: http://www.autozone.com/test-scan-a...oem-in-line-ignition-spark-tester/900800_0_0/
So back to the Four main things you need for an engine: Air: unless you have a towel stuck in your inlet you have Air. Fuel: Use the noid light, it's easier and safer to check if your fuel injectors are pulsing. Spark: Safer to use the spark tester to verify you have spark. Compression: unless the engine is really worn out but I'm going to assume it's fine. But a simple compression check can verify if compression is okay.
Timing: Do you know how to check your initial timing? Do you have a timing light?
I know that's a lot to digest but let's leave it there until you can confirm you're getting fuel and spark.
Good luck
Michael Plummer
As an Amazon Associate we earn from qualifying purchases.
Mustangt1995
Thanks for the help I figured it out took most the day but she's running lk a champ it had a switch to cut the fuel pump off tucked underneath the dash and I repalced distributor, coil and the ignition control module redid the ground for the computer and put a ground from frame to motor I don't know which one fixed it but hell she runs I'm happy
Michael Plummer
Brockton, MA
There you go!! The best Mustang is a running Mustang. You can always try the switch to see if that was your original issue and I would still pickup the Chilton manual, noid light and spark tester because I'm sure you're going to make modifications to your Mustang in the future.
Mustangt1995
The switch was just a fuel pump cut off still didn't get spark when I turned it on and I'm gonna pick up a chiltons book when I get off work I'm a mopar guy but hell I figure I would try the mustang life I always liked the 94 95s
Mustangt1995
[/URL][/IMG]
Lucky57
