1996 Cobra Speed Calibrator
cobraman
Jeffersonville, IN
Hi,
I recently got a 1996 Cobra and found that the speedometer is off. It has 410 gears and 18" wheels. I want to get a speed calibrator to fix the speedometer on the car. I am thinking about getting the ford racing one but thought I would see if anybody has experience with this one or any others I should maybe consider?
Thanks
lutter94
South Dakota
speedcal works well. dial the percent change you want it to make. pretty simple.
cobraman
cobraman
Jeffersonville, IN
I thought about that but what I heard is its not that accurate. I went ahead and ordered the ford racing speed cal
Sent from my DROID RAZR using Tapatalk
1997GT4.6
I have the ford speed cal. Works great, just as advertised.
lutter94
South Dakota
I used stick on velcro, stuck it to the firewall (engine side, in front of passenger seat). There is that main harness there, so I tapped into two of the wires. Want switched power, so it doesn't drain your battery.....
cobraman
cobraman
Jeffersonville, IN
Cool thanks. I was thinking about using some Velcro. Does it hold up well?
lutter94
South Dakota
Been awhile since I messed with it, but IIRC it's still good. All depends on the velcro you buy......
lutter94
South Dakota
Looks like his is in the same place as mine......
cobraman
cobraman
Jeffersonville, IN
Hey I just got mine but I don't have the circuit diagram. I ordered a manual but don't have it yet. I noticed the wires aren't very long. Did u connect the ground wire to another ground ground wire in the same harness as the other wires?
lutter94
South Dakota
I just grounded it somewhere on the body, can't remember which bolt exactly. But the instructions said which wire the VSS was that I needed to cut. I just used a voltmeter to find switched power in that big harness......
cobraman
cobraman
Jeffersonville, IN
Thanks I'm sure I will figure it out. Plan to mess with it later this week.
cobraman
cobraman
Jeffersonville, IN
Well its installed and my speedometer is now accurate. Now I'm actually going 120 instead of what I thought was 135
MustangChris
Aurora, CO
i have the FRPP speed cal. easy to calibrate, easy to install, non-functional with 03/04 Cobras (from what i can tell -- not that that would effect you. lol)
cobraman
cobraman
Jeffersonville, IN
Yeah I used the ford racing one. Easy to install and works great so far
SnakeBit!
Florida
I have a used one laying around somewhere that a friend needs. can anyone tell me what wires to tap into and which one goes where? thanx.
cobraman
cobraman
Jeffersonville, IN
Grey/black for the signal wire. The wire going towards the engine is the one going to transmission. I also tapped into the red power wire. You can get the speed cal wires from the website
marktuck99
