Welp....Old puts it like that....better change them!
Well I’m taking yalls advice and going to change them as well. More intimidation coming from this but it’s better to try rather than run away from it. Okay so I’m assuming I’d have to take off the valve springs?There is never time to do it right..
But there is always time to do it twice.
Crazy I bought a magnet like that from Autozone earlier when I went to buy valve cover gaskets! Haha well I got that what’s next
Will do man!Cams should be there today bro! Post some pics when you get everything.
Thanks so how much price wise should I be looking at? And it’s. It s permanent setup so it won’t see boost. Just n/a full bolt ons. I just want a fun reliable daily for now. And the seals yes I’ll do. If I can I’ll grab some coyote rods but I don’t mind reusing mine as they are temporary. What are some pistons and rings would you recommend?Just buy the pistons and new rings. No need to to spend more where its not needed. Your rods are power friendly naturally aspirated unless ford made a lighter rod, then id go with it!! But if you want to force feed this beast later, coyote rods hold up well and are cheap. Sorry about cheap pistons tho, cause the stockers really dont like the boost beyond 400hp and i wouldnt trust your stock rods at that level either.....force feeding just creates a snowball of debt for parts that hold up.
May as well do new rod bearings too. Any part store replacement like federal mogul will be fine. Same for the head gaskets too. You can re-use the ford headbolts and rod bolts with no problems.
I do recommend replacing front cover crank seal and all the valve seals.
Okay great thanks my man!Ill send a link
Aha thanks! Any specific year?Well...i dont have the time for links. Look for 5.4l navigator pistons. The pistons are not the same as 4.6l pistons and are lighter plus they are flat top. Actual ford navigator pistons would be best, but any aftermarket hyputectic piston should work out fine. I prefer speedpro. Get a kit that includes rings
Here you go
http://www.modmaxracing.com/product-p/22025003.htm
Youll want flat top and no bridge under the wrist pin. I call it a bridge, but its probably not the technical term. You see, the 5.4l got the lightest pistons. Looking at the pistons side view at the wrist pin hole, All the 4.6l pistons had more material under the wrist pin hole like a bridge. The 5.4l did not. Pair the pistons with lightened thin walled tooled steel wrist pins for more power potential!
Do these come with the wrist pins or?? I was reading it said it’d bump 10.0:01 compression is that true?Here you go
