1998 codes troubleshooting
GTCobra407
Our 98 Cobra basically is not driveable we limped it home and I checked the Sct BDX and it pulled up the following codes:
P0102 - mass air flow (replaced)
P0171 - lean bank
P0174 - lean bank
P1519 - imrc
Can any of yall put us in the right direction to get her car back up and running?
badass98svt
0171 and 0174 is either unmetered air entering the system, or not enough fuel(pressure?)
When you put the new MAFS in, was it the correct part #, matched to your injectors? No air leaks anywhere?
1519 is either the IMRC are stuck closed (dirty) or perhaps your IMRC actuator is no longer functional.
You can ziptie them open if need be.
I_LIKE_TURTLEZ
USA
Since the ECM thinks both cylinder banks are lean, the most likely culprit is a massive vacuum leak, do not forget to check the exhaust, all of our manifolds are leaking at least a little bit by now.
Common culprits are purge valve/solenoid, EGR, the plastic vacuum lines littering the engine bay of every 90's automobile(25+ year old ABS plastic is more fragile than glass..)
Strongly suggest not throwing parts at it, it will likely cause more problems because new doesn't mean good, especially when it comes to aftermarket.
If these faults occurred after installing the MAF, then that is likely the issue, MAF's have to be virtually spot on as they're incredibly sensitive sensors.
If these faults happened before installing that MAF, gently clean the OEM one and reinstall it.
Verify fuel pressure/volume, then go on the hunt for a large vacuum leak. A smoke machine generally makes quick work of this.
Beefcake-Racing
