Had Stifflers Sub Frames and fit system welded up today now running into a weird problem trying to get it up evenly on my two post lift. As you can see from the pic below the fit system blocks the lift pad from hitting the typical flat box where I used to lift from. This pretty much leaves my only option to use the sub frame connectors as my point to lift from.
Now my problem when I do this is the frame rail in the front where I would typically lift from is exposed but it sits a couple inches higher than the sub frame I lift from in the back of the car creating a situation where the rear is lifting faster than the front.
Front Tire Elevation:
Rear Tire Elevation:
So how do I even things out here? Should I move the front arms back on to the sub frame and if so would I have to move the car backwards to compensate for the weight distribution?
Should I lift from a different point in the rear? Not really sure what other options I even have there.
Or do I try to use a spacer in the front to even things out with the back?
Any help is greatly appreciated. Thanks.
