07GtS197
Did you swap heads? I didn’t know the oil fill was slightly different between the Windsor and Romeo. I don’t see it making a difference though since both were used in the bullitt.
Just kinda a throwback question.
Did you ever warm up to the looks of the silver control arms?
Your underside may be black but it seems to me if anyone did catch a glimpse of the arms, it would kinda make it pop.
I wanted to keep all of my engine bay semi gloss black. But after having to put on a couple of things I couldn't find in anything but chrome, I've warmed to it a little.
Its a simple extension tube that locks into the cover much like the cap does and the tube is removable but iirc it damages how it locks in when removed.
If Procharger doesn't have a idler pulley shaft/standoff that will work I'll see if i cant find a local CNC shop that could replicate the one i have and just make it 5/16 shorter. But looking on BruteSpeed's website it looks like they have a few different idler shaftsif there is an alternator specialty place in town I would stop by there and ask them what they recommend.
I just gotta ask, what did you make the restrictor out of, and how big did you make the orfice???"I got smart on the 3rd hose and made an orfice that slipped into the hose. Used a clamp to keep it in place.
Be careful with how your coolant lines are set up. They are inlet specific and the inlet side has a restrictor so it doesn’t build too much pressure at high rpm’s and burst.
^ this!!!
Dont make the mistake i did and run without the restrictor orfice. I popped 2 hoses before i figured it out.
The old original hose from the factory had one. The hose was old and gave up and i simply replaced it with what worked from the parts store. I dont remember why i just didnt replace with original type. Maybe it was a discontinued item or it was to expensive or maybe cause mine is swapped 5.4l and the hose is a tangled mess, but unknowningly about the factory restrictor, I got smart on the 3rd hose and made an orfice that slipped into the hose. Used a clamp to keep it in place. By then it was to late because i had to drive the car 10miles with no coolant and the head bolts gave up from the heat causing blown gaskets. Get the orfice!
(Fabricators like this stuff.)
