Ill agree to that! Even tho them plastic chits is what pays my checks...lol.
That hose goes from the throttle body to the vacuum canister in the fender well. Are you planning to keep the evap stuff?
I could use a passenger side door, if the shipping is friendlyNot much to update on this, got put on the back burner while I help a friend with his Evo 9 and wait for parts. Have made some progress. Got the front suspension and brakes pulled off, just have to drop the K-member then start sanding & sand blasting. I sent my steering rack out to Cardone to be rebuilt to 03-04 cobra spec as none of my local stores had that rack in stock and ironically the terminator rack was cheaper than a GT rack.
I also noticed that my ABS unit says "V6 Traction" which confuses me as clearly its not a V6 lol. However I have had a ABS light on for years and want to get it fixed while everything is apart. Now the question is, Do I order a replacement for a V6 unit or a GT?
Complete side note, does anyone need doors to a 94-98? I completely forgot I had both doors left over from a 97 I parted out
Do a search on youtube and there is a way to pull err codes from the abs unit with a paperclip to see what it is telling you is wrong. m It could be as simple as a dirty wheel speed sensor or something else that is not related to the main unit throwing the code. Pretty sure the v6/gt/cobra abs unit is all the same.Not much to update on this, got put on the back burner while I help a friend with his Evo 9 and wait for parts. Have made some progress. Got the front suspension and brakes pulled off, just have to drop the K-member then start sanding & sand blasting. I sent my steering rack out to Cardone to be rebuilt to 03-04 cobra spec as none of my local stores had that rack in stock and ironically the terminator rack was cheaper than a GT rack.
