Frustrating weekend but made progress nonetheless
The plan for this weekend was to get the UPR K-member bolted in as well as the entire front suspension and have the car on all four wheels for the first time in a year. That quickly changed once I went to install the K-member
Every simple bolt on is one misaligned bolt away from turning sour lol. I quickly realized that one hole was just enough off center to not let the frame rail bolt drop through
I can't blame UPR for this, as it is possible that holes were drilled out ever so slightly off center when the shock tower areas rust was repaired. I tried pulling the K-member over, adjusting the bolts on the opposite side as the passenger side is oval to allow for some adjustment. Nada. My only choice was to enlarge the hole out a tad more to allow the bolt to drop through correctly. Not hard just annoying to do. also, fuck those J clips as they scratched up my fresh undercoating
Once the UPR K-member was loosely in place my dad made the suggestion to make sure it was actually square. Grabbed some chassis measurement from specialize collision repair software and got out the measurement gauges. Ill post photos of the measurements below, maybe someone else could use them
To our surprise everything checked out! Which was a huge relief to me. I am still going to check it out with a plum bob just to double check. EricTheCarGuy has a great video on YouTube on how to do this.
Once the K-member was all set up I started getting as much of the wiring harness set in place as I could. The only harnesses I have left are for the top & Bottom on the engine and the trans harness. Got my offset Power steering rack bushings press in as well. Excited to see if the 03-04 cobra rack upgrade was worth it.
Plan for next weekend is to make up two brake lines that go from the master cylinder to the distribution block and get the front suspension all set up and get the car back on the ground... we'll see how that goes
