2000 GT, Another sn95?
joe65
joe65
installed this on the Mach yesterday. Really not bad at all. The under the dash part sucks but mine came apart pretty easily. Big difference in the clutch feel because i can adjust it now.
RAU03MACH
NEW MEXICO
i think i want my ram air box in operation again , right now i have it like yours , im going to make a cold air intake box that will hook up with the original air inlet and filter
joe65
joe65
yeah i was debating which one to go with and this one came up used at a good price so I bought it.
RAU03MACH
NEW MEXICO
Well what i wanna do is put it back to factory operation
But using a filter box that is sealed with the ram air intake
Just modernize it
I'll play around with it
Some sheet metal and mig welding should do it
But I definitely want the ram air working on the car
joe65
joe65
Just modernize it
yeah i can understand wanting it to work. I'd like to see what you end up with.
RAU03MACH
NEW MEXICO
ya i am going to take the shaker off and look at the bottom of it and develop a filter system
of some kind just something that works with it
RAU03MACH
NEW MEXICO
i would like something that is tucked under the the ram air that could hooked directly to a cold air intake
joe65
joe65
status of the car right now. pulled the starter to get to the exhaust stud/nut at the h pipe. this thing has been a thorn in my ass.
joe65
joe65
finally got the little sob out. had to remove the starter so i had any kind of room. Used my dremel with a cut off wheel, then had to use an air chisel/hammer to get it to turn loose. Anyways got it loose and pulled off and got the magnaflow x with the hi flows on it. overall, what a pain in the ass. But the stinger mufflers sound so good with the x...at 3k-4k is the sweet spot...
joe65
joe65
I've got some winter projects planned for mine. New K member, a arms,coil overs, bump steer kit, steering shaft, gears, change the tranny fluid. Hopefully get the heads and cams ready to go on the new short block. After seeing the F1 cars, i'm on the suspension band wagon. I'd like to do the brembo swap too.
joe65
joe65
time to pick up my short block.
joe65
joe65
made a decision for the Mach ....going boosted. Found a really good deal on a kit removed from an 01 Cobra. P!sc.
Musturd
Nice you’re Goona love the procharger. Everytime I see a azure blue Mach it makes me want one more
Snorky
Im glad you didnt go down the nightmare rabbit hole of a turbo setup. They suck. I debate about swapping back to blower once a week
bs.austin.tx
