Tap the persons post to highlight blue and look for the thumbs up at top right corner.
Heads and headers would be next on my list. The car has gone 13.57 at 102. Pre tune, cat deletes etc it went 13.8 at 98. and pre 4.10's it went 14.1's.... its a Vert so that slows it a bit too.
How big of a difference are you calling "big" 30 horse gain? You think it'd make that much? Why can't yall use stock headers w new heads?LT's WILL make a BIG difference in his setup. He is going to need them when he goes with heads anyways so why not start with the cheaper of the two to begin with...
You keep saying LT's aren't cheap yet they are... You can pick up a set of used headers and midpipe for like $3-400....
Look, right here on our very forum we have a COMPLETE exhaust setup for $500....
http://www.sn95forums.com/showthread.php?70206-96-04-Mac-Longtubes-X-pipe-amp-Mufflers-Dumped
Yeah I'd bet he would see every bit of 20-30 hp from them. I'm currently running stock manifolds with Fox Lake Stage 2 Heads and Hitech Stage 2 Cams and a local builder/tuner that knows these engines well(built a 400+hp NA 2v) said I would easily gain 30-35hp with them.
That's an apples to oranges statement though. You will gain more out of them than a car with stock heads. You're motor can pump in and out a lot more air than his.
Can you show me an example of a stockish 2v with long tubes that made 270-280'rwhp? I think that was/is around his target goal.'I'm not saying that because of what was said about mine. I'm saying that because it's been done countless times. Do a little research...
What's left to learn? You think he'll be satisfied with a high 13 second car?Man!....yo cup....runith over!!! Dump it out....lets learn
Ever notice manufactures claims of "up to" x amount of hp w x part? They didn't get x gains w a stock engine. All of the parts have to flow together to make max power, one continuos flow of air in and out. Right or wrong? Where's the biggest air restriction for this guy? Where's the biggest bottleneck? THE HEADS! Guys w aftermarket heads and stock headers make a lot more power than guys with stock heads and the freeiest flowing exhaust on the planet. Do a search, look at some graphs or just read a previous post in this thread about the guy who made 400 hp w a better set of heads and his tuner said he could gain another 30 or whatever w long tubes. Heads and compression make power. Everything else just "supports" it.^ first misconception of the internal combustion engine.
A thought such as that is detrimental to your thought process. Your way of thinking is set in one path. Im not bashing you here, dont get me wrong, im only helping you understand the internal combustion engine.
