2V-3V Swap vid and info.
rtgreen
Here is the vid ----> Video Here
The guy that did the swap stated that he used the 2V computer. I would guess that means that he did not use the VVT
(Variable Valve Timing).
He gave just limited info...hope he posts more soon. I've been kicking this swap around for a couple of months. Problem is my car is my DD, so I would have to do the swap with very little down time. I'd rather others do it first, find out the + and - then I can copy :)
Lightning Struck
350rwhp off a 3 valve with what appears to be only exhaust and some kind of intake tube ??? Sounds HIGH to me :-\ :-\
Neat swap non the less, however if I was to do a swap on a modular car it would be a 4 valve out of a Mach 1 car or a 03-04 TERMINATOR motor.
R
rtgreen
3V cars make just as much if not more than 4V cars. This particular car had a built 3V stroker.
Lightning Struck
ahhh well then that explains why it made at least 50hp more than it should have ;D, like I said neat swap but I'll go with the extra vavle or valves......whatever 8)
gutboybarrelhouse
Come on, you don't really believe that do you? "Just as much if not more"? Stroke a 4V and you'll get alot more than 350 rwhp!! I make 317 rwhp with an auto tranny and a few bolt ons.....
1996mustangGT
+1 to gutboybarrelhouse
for around or a little more go with the 4v swap.
the "potential" for the 4v is a lot better.
read: one more valve per cylinder=better air flow
Lightning Struck
+1
Sleuth
