2v heater core bypass
chad5.0
michigan
Is there a way to bypass the heater core off the block, I'm not running a heater core so just wondering if theres a way to bypass it from the block
KillNThrill24
Cleveland Ohio
Firewall is easiest. Just get a hose connector and connect them. I did that for a few months last year when I blew out my heater core
Sent from my HTC6525LVW using Tapatalk
chad5.0
chad5.0
michigan
I have nothing under the dash.. Its just the connection under the alternator is where I have to bypass it at
03DSGGT
SN95 Supporting Member
Akron, Ohio
Right, so the two hoses that you have that are right next to eachother at the firewall, the one coming out of the back of the intake, and the other coming from the valley, just connect them with a U shaped tube. If you don't have the hard line that runs down the valley into the back of the water pump, you can run a hose from the fitting in the back of the water pump up towards the firewall and connect it into the back of the intake on the passenger side...
duff daddy
Um perfect time to do the coolant mod d/d to p/s and a y connector back to watering pump
Sent from my SM-N900P using Tapatalk
RobertC
