2V Possibilities
Wichers123
Covington, louisiana
dirtyred11
dirtyred11
Jacksonville FL
No matter what you decide. Please for the love of God don't make the misstake I did, billet oil pump. My wot launch control broke mine.
I had looked at your build thread right before I made this post, you did do something with the 03/04 cobra short block and PI heads correct?
D3VST8R96GT
Marble Fall, AZ
I skipped the billet gears on my 3v build only because 1) its an auto 2) I will be replacing the cams after the break in period.
If you have a stick, gears are a great idea. The 3v's seem to break them often.
Wichers123
This is incorrect information. My car was auto when it broke the gears.
D3VST8R96GT
Marble Fall, AZ
Never said stick cars only. Def noticed the trend in 3v cars but it could be that most like a mt vs at.
It was about 3:1.....
But an auto def provides for less impact/shock
D3VST8R96GT
Marble Fall, AZ
Its the tentioners that cause the harmonics.
The oil passages for the tensioner are like 3inches form the solenoid passages that leads to the phasers...... I'm sure they play a pretty good part in part failures....
High rpm shifts, converter, or getting off the throttle hard......
96blak54
In the shop
Locking out the tentioners significantly reduces chains slap...that the tentioner can not over come. In rev limiting scenario's, the timing components dont follow along with how the crankshaft bounces quickly from 2 separate rpm's. The timing components are designed to pull and keep loaded in a pull scenario(tentioner arms) but as the crank bounces off a limiter and rpm drop, the rest of the components go into a slight free spin/fall and then suddenly get jerked when the power comes back on....but really quickly shifting rpm's. The chains start to get a rythmic wave, and the tentioners cant handle the chains weight slapping the arm around, ultimately allowing even more slap. This goes unnoticed because most dont rev limit/2step and its all packaged behind a cover. The constant supply of oil pressure behind the tentioner acts like a shock.
The fix?
Easy....make spacers for the insides of the tentioners to back up to..locking out. This requires a little skill figuring out what spacer size is needed.
This still does not stop the oil pump gears from breaking from harmonics, but correcting this helps tremendously reducing unwanted harmonics.
DropTopPony
South Jersey
You got me :)
I would even buy one from MMR if needed. A really good shop in my area is a TSS dealer so I went with them.
D3VST8R96GT
Marble Fall, AZ
is TSS better than mellon?
Melling? They have reported pump failures on the 3v side....
MMR sent a guy the wrong gears and it destroyed his oil pump upon install. They sent him a free hurricane pump but it worried me enough to sway mypocket book to TSS when i do get the gears.
TreeScholar
