I know for one I am going the 2V route because its more of a spectacle to see a fast 2V versus a 4v. When you see a fast 4V its not that out of the ordinary, but when your 2V is fast its like everyone looses their minds haha. I reallly like the head profile of Twist wedge design, running a sick cams that doesn't cost close to 1000 dollars is a plus too.
Nothing is really spectacular any more.... there are faster, there are people who make more power, who do it with less modifications to cylinder heads, block and driveline. Build the car to suit what YOU want but not what people will think is impressive
I've done a few 4v swaps and they are not hard at all. Engine, Harness and tune. (and petty stuff)
easy stuff you know swap block few wiring connectors and /thread. But the price you pay for a c-head long block + modifications for the power your looking for comes at a price.
Just curious, if all things being equal would you expect a 2v to be neck and neck vs a 4v?
Depends in what application, by design a 4v will always flow more air in stock configuration. (both power and weight, iron/aluminum block dont forget)
Yes, and when you factor in the extra cost for Boss blocks, big bores etc it gets you back to the question, is it really worth the money to get a NA 2V up to 400rwhp when FI is so easy and a much higher ceiling.
Unless your racing in a class that requires it, NA 2V builds are not the way to go.
With mine I only cracked 275rwhp and thats with heads/cams etc through a 4r70w, that took the big bore plan I was thinking of right out of the equation.
Stock short block and PI heads and lumpy sticks put me at 302/310 ... that was a pretty easy build, but if your going to do it, snag an NVH block, and make it a 327 bb/stroker and be done. I have seen a few done and make great power for little money (relative)
Yeah it seemed more reasonable to go na if I was going to use the built 5.4 4v I have.
WEIGHT WEIGHT WEIGHT WEIGHT, unless you shell out 5 grand for an empty block and a "dry sump" gt block....
We have a local 2v guy here running TF heads putting out 408HP 328TQ. Not sure of the bottom end specs but Dayton Performance is who tuned it and I am pretty sure Mike built the engine. Maybe we could get him to chime in on some info.
NXcoupe, where are you?
Mike knows his shit and built Camerons high cr 2v which is a TFS car and made over 400 and still had a good bit to grow.
I think 420-440hp crank with H/C/I 2V is respectable N/A, that is my goal. I just hope my shortblock is healthy for those numbers.
Dont rate these engines in hp at the crank, a c4, 4r70w, or t45 will drop those numbers, but lets not even get in to the converter debate....
I wanted to have decent power and do it with an engine people say it wasnt worth to do. I make decent power.
Sent from my LG-D801 using Tapatalk
Dick measuring contest anyone. This is WHY i wont put my car on a full dyno pull yet datalog and game boy the shit out of it.
duff daddy
Sent from my HTC6525LVW using Tapatalk
wtf why you drag me in to this !!!!!
Honestly to answer the coyote question.....
if I had known the option of a coyote swap for under 10 COMPLETE was an option when I built my car. Id have that right now. The performance, reliability, the versatility, cant be beat per $$$
