Local guy has a 2v that has about 12k in the engine and he's just about maxed out at just over 410 rwhp. Something like 11.5-12:1 compression and custom cams that are "about" a Stage 5 or so. Not worth it imo. You can DD a car with a blower and make that power plus save $5k+. Just not really feasable with N/A.
After this thread, I just want to go supercharged lol.
Like you mentioned earlier, can't hurt to build up a great foundation with rotating assembly, heads, intake...and really the only thing you will have to decide is the cam grind on if you plan on going f/i but you will make tons more power starting from a solid h/i setup
I do. Actually thats been the hardest part about looking at complete heads from MHS, I'm torn to which cam I want, I was looking a CMS/cushman, Comp cams etc but its hard finding a cam that a good N/A and works well under pressure. You can can always buy new cams but who wants to waste money? They go for 600.00 already so doing it twice is like 1200.00 - 400.00 if you sell it.
Cant go wrong with Fox Lake heads either. I have yet to hit the dyno due to my tranny problems but I will tell you before my T45 died the car straight ripped. Similar setups to mine have put down 325-335. My buddy rtvickers owns a 600hp Terminator and he was impressed with it so thats gotta says something.
Yeah I completely agree with ya, why do twice the work and spend twice the money. If you are planning on going blower down the road you should really go with a blower grind cam while you are n/a, the gains really aren't spared all the much, but its just the opposite if you run n/a aggressive cams in a blower setup it will really hurt you...just food for thought. I found out first hand when I used to run n/a cams with my blower setup I was barely seeing any boost and it was going right out of my exhaust due to the grind, they simply don't have the duraction and lsa that boost likes. I think all of those companys that you listed can take care of your power goals its just a personal preference.
I remember back when VT now Cushman was really popular everyone was running their cams in 2V's. The stage 2 NA and Stage 2 Blower cams were making @ the same power on NA cars. If your gonna go FI just get the blower cams now.
Absolutely, you'll make very similar power to n/a cams, maybe a little shy of what they would but the main thing being when you did go blower you have the best grind already setup and you are set.
Careful
Turbo vs blower cams is a more noticeable difference
The D3V
That is what I am looking for!
which one is it?
Turbo cams you want a certain LSA and durations to be about the same.... blower cams tend to have longer exhaust duration. Turbo cams don't look (on paper) or sound aggressive. Hell the stock 5.0 can is decent turbo cam from what I read ( modular guy here). I was under the impression the a can built for boost was built for boost but a turbo works dif then a s/c
As a general statement that has exceptions
N/A and blower cams are similar
Turbo and stock are similar
A good thing to do is look at all the can makers specs
Compare Cushman blowers to NA to turbos. Then do it to MHS cams.... I see a trend
The D3V
I think blower came work good as N/A cams but N/A cams don't work well as blower cams. Again a general statement with exception....
The D3V
