D3VST8R96GT
3v?!?!
The D3V
The D3V
Ok burninrock24...a little quiz for you. What is known by the use of 2 intake valves in a cylinder? Your answer can not be or related to "more flow". Im not trying to be a smarty pants but i am offering the readers a challenge.
Ok...I just got word about a guy in the next town over, Frankfort ky. He swapped on top of his stock short block a set of tfs heads with cams and a typhoon intake and netted out 404rwhp tuned at Blankenship. Im investigating the mystery and will report my findings.
TF heads have a high enough vale placement that you don't need the pistons fly cut?
^ good info there
From the description from trickflow the heads are drop in heads with no modifications.
The Mustang I went to look at was junk. :0/ I shouldn't really be looking right now anyway but if something nice falls in my lap, I'll lug it across the country when we move again.
No modifications when using factory internals and factory cams, correct?
You da man burninrock24!! Good info but let me challenge you more....?
I know why mr. Vizard likes the 2v and I think you should know too, but to give you the answer I was looking for about "whats known" with 2 intake valves. Tumble is guaranteed by using 2intake valves, regardless of port shape, valve angle, or intake length and this is known by all manufacturers in pursuit of simple hp and efficiency. Yes 2valves offer more flow potential in a tiny cylinder were one large valve would suffer, but the "tumble" is more sought after over flow. The flow of 2valves is a very positive by product that cant be utilized by manufacturers keeping the vehicle street drivable. Pm your email and ill send you a few very insightful links.
All the info you stated is correct and far more beneficial than a 2valve train. Not to mention the hp potential with the stock equipment!!!!
So what do you guys think of these blower cams with some tfs heads? Think they will make some decent power n/a? http://www.lunatipower.com/Product.aspx?id=2568&gid=289
