wmfateam
Having a major misfire around said RPM. Mainly going around hard corners on the track. Changed plugs, gapped, wires, coil packs. The only codes I have are secondary air pump, egr solenoid no dignal. and intake manifold runner bank 1 stuck open. The EGR is unplugged and the air pump is removed and capped off. When the car is cold, the first time threw 3,500 rpm, the car bucks a little, but second time it is perfectly fine. The main time it happens is hard cornering, or coming out if a corner at around 3-4000 rpm. It is killing me and letting others pull away exiting. Car is a 1996 Cobra that sees only race track. Tried searching, no dice.
Sent from my XT1254 using Tapatalk
