3.08 to 3.73
justinschmidt1
so i got my new gears in and I swear its hard to tell if its anyt faster....in fact I kind of liked the other gears..first gear went to about 50 and 2nd was about 90...now it never wants to downshift to first and even when its in first..It doesnt feel faster...I swear it was faster with the 3.08s..is it even possible for my car to be slower with 3.73s than it was witjh the 3.08s?
you should feel a MAJOR change with those gears, I dont understand why you dont :santa_huh:
Fets
Yea, when I got my 4.10's in I was like daaaamn :santa_shocked: Now I need new tires from all the burnouts I've been doing "Accidently" :santa_wink:
Daywalker
I went from 3.08s to 3.55s a couple years ago, and from 3.55s to 4.10s just this past weekend. The difference was VERY noticeable(in a good way) both times.... :banana:
19mustang95
i can only go to about 35 in 1st gear. :dunno:
maybe i have gears already.
RIFTER11
Nashvegas
Did you put them in yourself, or did someone put them in for you like a shop??
i'm thinking you probably got screwed and they kept your 3.73's :dunno:
i went from 2.73's to 3.73's in my old fox and it was like having a completely different car.
you should definately be able to feel a difference. :eek:uttahere:
J
justinschmidt1
its definately faster..it just felt like it pulled alot more with the 3.08s..I dunno less shifting maybe..the car just kept pulling to about 50 in first..with the tires cuttin loose at the top of first
19mustang95
with the 3.73s or the 3.08s you can go to 50 in first?
FST-HUH
I say you go with 4.10's and you'll see the difference big time. "DON'T FEAR THE GEAR" :santa_grin:
scarface
I didnt have 3:08 I had 2:73's. However, when they were changed to 3:73's it was like night and day!
Was your speedo correct before the swap? If it was, have a friend pace you now and see if it is off/correct. THen you will know if you got screwed.
J
justinschmidt1
yes it was..what would I be getting screwed with...I supplyed all the parts..the 3.73s and the speedo gear..
scarface
just because you supplied it, doesnt mean it actually went into your car man.
Red96GT
Or you could jack the rear end up, rotate the wheel one time and count how many times the axle turns.
ogbatman
Gears make u faster. Just launch harder. Gears help put more of th TQ to the ground but it want make ur car faster.
J
justinschmidt1
the gears definately went in..the problem is probably the tires i i have and its cold out..I cant get traction...so its hard to tell..its definately quicker out of the hole
silverstang1996
i have 3:73's in my car and it still feels too slow to have them i believe, i have tiny 16-17" rims and i can't even get my tires to spin off the line if i slam on it :santa_sad: (i do have an auto) but i would have thought those low gears would make my tires spin from a stop.
