4.6 coughed out a spark plug
Discussion in 'General Tech' started by Michael Soldan, Jun 17, 2019.
  1. Michael Soldan
    Michael Soldan New Member
    83
    13
    Feb 20, 2017
    Exeter Ontario
    Well my F150 4.6 coughed out a spark plug. Mechanic thinks he can fix it with a Heli-coil. I watched a couple of youtube videos on using heli coils. Just how reliable is this fix going to be or should I bite the bullet and pick up a head at the auto wreckers ?
  2. ttocs
    ttocs Legend
    23,875
    1,196
    its the best alternative to replacing the head. When done right they can hold up but its not something that either ford or a race car would want or recommend.
  3. 96blak54
    96blak54 Legend
    6,878
    288
    Feb 21, 2011
    Ky
    The brand "time-cert" and " locknstitch" are the best fix. Helicoils are cheap fix, but back out over time.
    Should you decide replacing the head/ heads. Look for 04-up model years, duch as crownvics, town cars, Econolines, and service trucks with 2v engines. Their heads have 8 threads in the sparkplug holes
    Sent from my SM-G900P using Tapatalk
    white95 likes this.
  4. OLD H2S
    OLD H2S Well-Known Member SN95 Supporter
    1,063
    126
    Jul 4, 2015
    Silver Spring Maryland
    I have used the Timesert 5 times on friends different F-150s, good and strong, helps if you use the big kit instead of the cheapy ones. Then I started to put them in all my heads, 8 at a time
  5. az97cobra
    az97cobra New Member
    Oct 3, 2014
    While my engine was at the machine shop I had them add the timesert inserts to all plugs. they told me they install them all the time and have done more than 500. After I went to the track the first time and went to pull the plugs and have a look, 5 of the inserts came out. I called the machine shop and they said they've never seen that before and he seemed sincere. What the hell happened I wondered? Are the inserts unreliable if used on the track? I didn't over torque the plugs since I always use a torque wrench so I don't want to get into a battle over torque here.
  6. ttocs
    ttocs Legend
    23,875
    1,196
    for track use you really don't want band aids on the motor or they come off. that is all this literally is, is a band aid/best available fix for a bad design.
  7. OLD H2S
    1,063
    126
    Jul 4, 2015
    You torqued the plugs too tight, max is 15 pounds and 11 is the norm.
    When new the inserts must be heat cycled to set the lock tight and the plug torque was higher than the insert torque.
    Glue them in again with green bearing retaining compound and use a torque wrench...really. I try to guess the torque and then check and I am both over and under.
  8. az97cobra
    Oct 3, 2014
    I did find online a Loctite 620 which goes up to 450deg. Most of the others I found only go to 300deg which doesn't seem sufficient.
    Not sure what to do with this statement. I'm not going to toss these ported heads.
  9. ttocs
    ttocs Legend
    23,875
    1,196
    no one enjoys writing the check for new heads and figuring out what to do with the old stock ones no matter ported or not. I am not saying they are complete crap and to ditch them. Use them till you are tired of messing with them but I would start keeping your eyes open for the next set if your going to continue at the track.
  10. OLD H2S
    1,063
    126
    Jul 4, 2015
    I got 2V PI heads for you..stage 3.
