Well, [MENTION=19540]Rolltide1006[/MENTION] how did the weekend turn out for you?
Hey Warrior, ya the folks at worldpac sent me two of the same motor mount lol (I work at a European shop lol worldpac is convenient). Got that problem solved yesterday. Now I am waiting on the new ARP flywheel and crank pulley bolts (I'm an idiot and didn't realize they were torque to yield until yesterday [emoji16]). I'm hoping to have an open bay after work tonight to at least drop the motor in and start throwing pumps back on and start the harness fun [emoji1303]
Sent from my iPhone using Tapatalk Pro
Get parts where you can! You should have just ordered some maximum motorsports solid engine mounts and called it a day!
Make sure to take pictures for us.
lol I was thinking solid mounts, but thought that would be too much for a daily driver.
And will do!
solid mounts are no problem at all. I've got about 3k miles on mine. They feel great
Cooperate?....goodluck with that!
Sent from my SM-G900P using Tapatalk
She lives!!!! Idle is a little low, definitely needs that tune, but it idles pretty darn good for being a stock tune.
https://youtu.be/qSAZ6r_7w3U
Wow I'm glad you posted some good detailed shot of the process of installing these. I was a little confused with what to do with the rocker arms upon installation of the cams. I see some people that bolted the cams down on top of the rocker arms and some that installed the rocker arms after the cams were bolted on.
Also I lol'd at the end "My car look good @ night"
Ahh glad to here you say that lol I did it that way on my Supra a few years ago and it worked out fine.Put all your followers in place and bolt the cam down evenly on top of them. Its the easiest way.
Sent from my SM-G920R4 using Tapatalk
Great info! Crank Keyway at the 9oclock position = All the pistons below the ptv contact areaLol! Ya I learned the hard way. I first bolted the cams down and tried the screwdriver trick with installing the followers on the lash adjusters. No bueno with my setup haha. If it was all stock valves and cams it would have worked.
So I took the CMS cams back out, installed the lash adjusters and followers. Then bolted the cams down. Key was to make sure all pistons were below the deck and then just work the cam bolts down in sequence, little by little until bottomed out. Then torque to spec in the same sequence
