42# injectors on stock pcm???
BlownSN95
I want to upgrade to 42# injectors and ditch this fmu. I have a 76mm c&l maf. Can I just get the correct tube and install the 42's? Or do I have to change anything else? Also I see on the c&l site 42# injectors aren't listed for a 94-95 GT with the 76mm unit. The 87-93's use the green tube. Anyone know if the green tube is needed for the 94-95 GT as well? Thanks for any info.
Matt94GT
Well if your maf has the diffrent sampling tubes then yes just pick up the correct tube for the 42# not sure on the colors but I would just call someone that sells C&L
B
BlownSN95
I called C&L and they said to use the red tube for 42's on a 94-95 GT. They list that tube for 36/38# but that is what they recommended.
Julian Moore
Lee Bender knows his shit..those tubes are a pia, why I swithced to a pro-m. Are you getting a chip burned after the install?? I run 50 pound injectors, car ran PIG rich, but after an sct chip and tune form KAufmans..WOW!!
B
BlownSN95
I was trying to get away with it for awhile. I know I need a custom tune, but they have noone local that I trust. Mike Murillo is about 7 hours away. I'll probably trailer it to him when it's time.
bs.austin.tx
