The t56 feels really nice. The t45 can feel the same because they share the same design. The t45 just needs some help.you did the magnum swap right? hows the feel of that thing? the t45 seems kinda finicky.
Awesome. He may reply tonight, if not, he will definitely reply tomorrow. He was quick to help me with a problem I had and was great to do business with.Warrior,
I just left Stan an email!
I have the close ratio on my magnum with 3.55s and it is a nice combination.I used a T56 from an 03-04 Cobra to replace my T5. Has a higher first gear (2.95 vs 3.35) which makes first more usable and a higher 6th gear for highway cruising. Problem for me is that I need more rear gear though as I wanted to get the trans in first to see how much gear I’d need. For my purposes, I think a 3.55 is likely ideal which is what I believe the transmissions were setup for initially anyhow. I did have to wire up a reverse gate override though to be able to shift into reverse and use a Speedcal since my T5 was gear driven and the T56 uses an electronic sender.
