JeremyAlan
SN95 Supporting Member
Alright guys this is the plan:
CTS-V 6 pot brembos with GT500 14" rotors and a custom fabricated adapter bracket for the caliper to mount to the spindle.
The calipers are going for $278 for one side and $240 for the other. I got a quote from rotorpros.net for GT500 rotors in the $250 range.
You'll need the caliper pin kit, which is around $21. For me, the hidden beauty in this swap is the availability of relatively cheap pads. Because of the OEM CTS-V(other manufactures too!) application of these calipers you can easily get pads and have a broader selection than with a specialty caliper.
Here is a shitty photo of the CTS-V Caliper I took
These calipers are superior to the Mustang's in many aspects, for example the piston sizes vary to ensure even pad wear in heavy use(track) situations. They are a monoblock design and give a firmer pedal feel, they handle heat better, etc..
What I have become most concerned over is pedal feel and brake bias. I ran the specs for the stock setup through a bias calculator and it returned a 71% forward bias. The new setup with stock rears returns a 74% forward brake bias. I see that as negligible, am I correct?
I'm currently working on how pedal feel will be affected.
Let me know what you guys think!
-Jeremy
-Jeremy
As an Amazon Associate we earn from qualifying purchases.
