No there wasnt, and that was my initial concern with this kit. If I had to do it again Id go with the 13" kit to get more used rotor space. However I do have full pad on rotor contact.
Oh, I can see that the pad on rotor contact is really good, it's kinda like the case with factory Cobra rotors. If I recall correctly, the pbr calipers were originally designed to be used with a 12 inch rotor, I think C4 Vettes used them. While moving them further out increases brake forces by increasing the leverage, it also comes with the penalty of the larger rotor weight. Maybe you could look into a two piece rotor. I've seen some of the larger kits where the sweep area wasn't that big, but it was a two piece, so the center hub was huge and therefore light. Then again, if the car stops well, and it's a street car, shouldn't really matter that much.
