600whp ?
ThatSNninety5
I need some opinions, my goal is 600whp and I want your guys input. I have a 1998 GT with a 4.6l from a 2005 Lincoln town car. I plan to build my automatic transmission with this build. What forced induction to go with, what brands to use, what all I need to upgrade. Anything you guys have!
RAU03MACH
NEW MEXICO
thats really up to you
it is a tall order for 600
supercharger will get you close same as a turbo or centrifugal supercharger
you would still need to beef up the engine some what
98snakehorse
Southeast, IA
Build engine first, your not hitting 600hp reliability with the cast pistons and rods. I've had both centrifigul and turbo chargers on my 98gt. The simiplicity of the supercharger was very nice however the power and tq gains from the turbo is unmatched.
I was in the high 500rwhp range with a built engine, stocks heads, cms cams and precision turbo on around 15lbs. My engine was also out of an 02 lincoln town car so it had the PI heads.
Snorky
Having been down this exact road already. I will ask a few things before giving any sort of advice or insight.
1. What do you plan to use the car for? Be extremely honest with yourself too. Is it going to live and only run at the drag strip? Or are you looking for something to just do some occasional pulls with and have a lot of badass theatrics while cruising?
2. What fuel do you have at the local gas stations?
3. How are your mechanical abilities?
4. If you had to put the car up tear into the forced induction system for a weekend every couple of weeks because of XYZ problem, would you be okay with that?
5. If it greatly makes you question the reliability of driving the car for long periods of time, are you okay with it?
6. Are you okay with it riding like a bag of shit in comparison to some lowering springs?
7. How do you want the power to come on? All at once and fall off at the top? Straight, predictable linear power? Or nothing nothing then everything and then some all at once?
Let me know and I'll give you my 2 cents.
ThatSNninety5
ThatSNninety5
My plan for the car is to have something to drive when Im driving by myself and not with the family. For example to the store if I go alone, a nice weekend car so roughly 2-3 times a week. But id like for it to be fun and if im on the highway and someone wants to do a pull next to me I can put some power down. Occasional trips to the track or strip
My local Sheetz has 87. 89, 93. Flexfuel/E85 and Unleaded 88.
My mechanical ability is pretty good. Ive swapped the motor and trans in this mustang and have had a couple pretty deep electric problems ive been able to figure out myself. I tore apart the old motor and trans after the swap just to get an idea of what failed etc.
Id be okay with tearing it down on a weekend for maintenance or even issues needing addressed.
Id like do keep it reliable for the sake of not getting stuck at a grocery store etc.
The car already has Eibach 3510.301 lowering springs and Bilstein B8 shocks so im pretty used to the rough ride is has already
Im not sure how I feel about how I want the power to feel since ive never had a car with any sort of forced induction.
Snorky
Well.. turbochargers make an assload of power.. period.. that being said they can be jackstand queens and can make you paranoid everything will begin to melt. Wrapped and away from things or not. You will have a tubular K member, A arms, coil over suspension just to make it all fit. Pipes, oil lines, vacuum lines going everywhere. Leaks leaks leaks. It sure does make a lot of power though! Lol. How the power comes on is dependent on the turbo sizing. If it'd sized on the smaller end. It will act like a PD blower. Wait a second or 2 and then you have all of the mid range torque of a PD blower and then some, but it will fall off at the top. A little larger then you wait and it builds on the high end. They are sensitive to sizing.
A blower is very simple and reliable, but less power than the turbo. Set it and forget it nearly. The only time I see guys irritated over their blowers is when they have boost cranked to the extreme and it might chuck a belt. A centri blower feels like an NA motor.. only MORE!!! Higher the rpm. The more power it makes all the way to redline. Smooth, predictable. Linear
A Positive displacement blower(kenne bell,Whipple, tork tek) you have the maximum amount of torque at any rpm. The hp climbs nicely but will eventually drop off in the upper rpms. Great for doing burnouts.
Basically the turbo is going into the deep end, heavy front end suspension work, special exhaust work sometimes needed.
The blower setups use the standard exhaust parts, standard suspension parts, centri blowers love the numerically higher gears.
Just food for thought. Everyone has different experiences with their turbo amd blower setups.
ThatSNninety5
ThatSNninety5
So my current exhaust set up is BBK Shorty headers, BBK non-catted/offroad H pipe to a spintech side exit kit with 333SDS mufflers. Id love to keep this exhaust setup because I put a good bit of money into it, just installed it and welded it with my buddy. The obvious answer would be just go to some sort of blower to keep my exhaust. But at the same time if I do any kind of forced induction id love to get a cobra style front bumper with the circle fog lights and see the spool of the turbo through that fog light opening. There just so many options. What are your thoughts?
Snorky
My 67mm Precision turbo hits hard at anywhere about 2600 RPM
That's a good size. My old 67mm didn't spool that well, but made a tremendous amount of torque.l though. I think my wastegate I'd messed up
I might be wrong but 600 whp for what you are describing will beg the question of what the budget is? Getting that number to be reliable on the older format engine will not be easy or cheap, keeping it will also take some time/cash for an occasional strip trip or street light drag. Don't forget the trans/rear end....
badass98svt
Yes it is a great size for the street.
The 76mm would make the 600, but would take a little longer for the boost to come on. But man, hang on when that happens.
Snorky
So I ordered a new wastegate, lol I am determined to make this thing right!
If you've never been around any forced induction and you're thinking more about a Cobra bumper to hang the turbo in the front bumper, but you've got "a lot" of money in BBK shorties, you are vastly unprepared for the amount of money it would take to have a reliable 600whp and what that would feel like in a wet noodle light chassis like a SN95.
Find a used Vortech kit, make sure your fuel system is up to snuff, and start there. Used kits are on FB all the time from $1500-2500. You could very easily end up with $1-2k in fuel system and tuning and you'll end up with a solid 300-350whp. If you decide you want more, then start stockpiling motor parts and get ready to go through the engine. But more than likely, if you get the Vortech on, you'll find that a real 300whp in one of these cars is pretty fun and obtainable.
ThatSNninety5
ThatSNninety5
That definitely is a good idea. Maybe I should just start small like that. Currently I have a Walbro 255LPH fuel pump I just put in and bosch 22lb/hr injectors. So with that being said what could I throw at it? I appreciate the comment!
Snorky
Yes! Get it done! Boooooooost
I want to know what the 7575 feels like with 14 lbs and no leaks. If it's not appealing and all top end then perhaps I'll go back to a 6765 again or something.
nynce
