8.8 posi need help plz
MiStangGtBangs01
st. louis mo
Hey guys and gals so I have a bent rear axle so I threw the rear of the car on jacks on stands and i began to spin the wheel to check what side is bent and i realized i have posi now idk what ratio i have i boutght the car with it and wasnt aware it is posi so i need to know how to figure out what gear ratio i have. Rly appreciate any input thank you
Phoenix0783
Posi doesn't determine the ratio. Read the tag on the diff cover if it's still there. Otherwise just count how many times the pinion turns each time you turn the tires one full rotation.
RichV
CO
All GT/Cobras have a 8.8 trak-lok. OEM ratios will be 2:73, 3:08, 3:27. Some exceptions to this. Aftermarket can be a lot of different ratios.
Make sure BOTH tires are rotating together when doing this.
no you'll still have an internal slippage. (open diff)
Do you have the origional tag on the diff?
jhonswilliam80
