80mm C&L in a 95??
JBCleary
Is anyone running an 80mm in their 94/95? Trying to fiqure out what sampling tube to use with 30lb injectors but the C&L site does not show an 80mm in the 94/95.
It appears that 89-93 sampling tubes are a different size than the 94/95 tubes for the same diameter MAF. (76mm for instance)
Anyone know why?
J
JBCleary
Julian Moore said:
Call Lee Bender at C&L...(256) 882-6813 . He's a great guy..he will help you!
Well I talked with Lee. Boy! this guy is a wealth of information!!
My setup I had planned is all wrong for a 94/95 so it's back to the drawing board.
I need to dump my pre-94 TB setup and the 80mm MAF and get the 94/95 version with a 76mm MAF if I want to stand a chance with the 95 GT computer at all!
Not to mention the idle problems I 'might' have with the 30lb injectors.Time to get my Turbolister fired up to sell these goodies on EBay :D
Dalamar
SLC, UT
I have not heard good things from tuners about the C&L's
mine ran like shit...
J
JBCleary
What did you end up going to?
I was thinking a Pro-M setup.
Has anyone tried the Granitelli or Summit MAFs in their 94/95's?
Lee also told me that the 30lb injectors which I have, have a different spray pattern than others and can cause idle problems.
Anyone running 30lb injectors without issues?
Julian Moore
I ran 30 injectors with a C&L and the correct sample tube. Car never ran well. I switched to a Pro-M 80 with 36 pound injectors and I am now running 50 pound injectors with the same set up! As I always say.....it the tune that makes it run right.
Sleuth
