94-95 TB ?
ryclef331
58mm I believe. Really all you need to know is "too small."
Yep ^^ 58mm. Get a 70mm if you get anything. All the manifolds I know of have 70mm openings.
97vertstang
Midnight_Cobra said:
It's also not legal where I live, so I don't even bother looking at the specs.
do u need a carb number for a throttle body???? only bbk has a carb number and i wanted to give summit TBs a chance but no carb #.
94twinscrew
In some states like cali,yes...or they will fail you.
94twinscrew
Willis,I would just get a 70mm,anything after that is just overkill on a n/a engine. You also will loose a little throttle response down low,but it will level off on the top end.
Sn95Willis
Sn95Willis
Baytown Tx
Yea i figured that a 70 would be the best bet.. I can pick up a FMS 65mm TB for 25 bucks.. Would that be ok for now....
Willis
I was talking about the trickflow intake, not the TB.
94twinscrew
Willis
$25 is an insane deal for that....grab it!!!
Unless you're blown,you won't see any difference between a 70mm to a 65mm....atleast with a 65mm you get to have better throttle response.
Trickflow.GT
is there any diference between the 87-93 TB's and ours....its gay that accufab doesnt make one for us :nonono:
Trickflow.GT
yea but i want to know if the 87-93 ones (like accufab ones) will fit on 94-95 cars
Trickflow.GT
aacufab is ignorant though do they not realize how many people are not running stock intakes....and have NO egr's....they should really re-consider making ones for us...
bs.austin.tx
