94 electric key problem.
9394stang
1994 Ford mustang gt.
New clutch safety switch.
New key ing the one you put the keys in.
The ing box with wires under the new key ing
This is the one where the pink and white wire seems to not have any power going to it to start the car.
Where does this pink and white wire first get its power from does it come in by the ECM or get its power from off the key ing .
If I jump the trigger wire off the starter the car starts and runs good and I can shut the car off with the key it just won't start with it.
All lights work and reverse lights.
Clock radio does not .
I have been battling this problem all summer I had to stop working on the car to help a family member and now I have some time this weekend.
Thanks.
9394stang
All good .
Fan comes on when I do start car with jump wire.
And stay on.
Cruse does not work not sure if it ever did.
I tried to read codes with code reader as check engine light stays on.
When I plug obd 1 code reader in I here a click at the relay in front but no fans come on and no codes come up.
According to you tube the fans should come on when trying to check codes
95opal
Thanks.
Here ya go
nynce
