StreetPilot
Hoping someone has run into this issue and can help me figure it out. The other night I went to fuel up the car and it wouldn't take gas. Pump kept clicking off. Thought it was the pump so I went to another gas station. Same thing happens there- pump clicks off after about a second. If I try to fuel VERY slowly (about three pennies worth per second), I can get a little bit in at a time. Took five minutes to get three gallons into it.
It acts like the tank is full, but the gauge seems to be working and if I go slowly I can get gas in it, but it takes forever (pump handle keeps clicking off if I go other than uber-slow). My guess is that whatever allows the air to escape the tank when you put gas in is not working properly. Is this the EVAP system clogged up? Maybe a bad charcoal canister? I've never worked on that system on any of my SN's, so I don't even know where to start. I looked down the filler neck with a flashlight last night and there doesn't appear to be an obstruction, but I don't have a boroscope to see past the curve of the neck. Any help is really appreciated.
Jeff
P.S.- I have no idea why this post is so dark compared to others.
Jeff
